Try
https://localhost:8080/geoserver/wcs?SERVICE=WCS&Version=2.0.1&REQUEST=GetCoverage&CoverageID=test&format=image/geotiff&subset=lat,http://www.opengis.net/def/crs/EPSG/0/4326(34.53627,38.88686)&subset=long,http://www.opengis.net/def/crs/EPSG/0/4326(25.43366,31.32234)
Where 'lat', and 'long' are the names of the axes reported in your GetCapabilities response.
James
-----Original Message-----
Sent: Wednesday, August 26, 2015 12:21 AM
Subject: [Geoserver-users] Cannot specify subset in WCS 2.0.1
Hello,
I'm trying to make a WCS GetCoverage call on a subset of a coverage like
below:
ST=GetCoverage&CoverageID=test&format=image/geotiff&SUBSETTINGCRS
=http://www.opengis.net/def/crs/EPSG/0/4326&outputcrs=http://www.op
engis.net/def/crs/EPSG/0/4326&SUBSET=lat(34.53627,38.88686)&SUBSET=lo
ng(25.43366,31.32234)
But it keeps complaining with the error
<ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:ows=http://www.opengis.net/ows/2.0
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0.0"
xsi:schemaLocation="http://www.opengis.net/ows/2.0
http://schemas.opengis.net/ows/2.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="InvalidAxisLabel" locator="lat">
<ows:ExceptionText>Invalid axis label provided: lat
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I have tried multiple axis labels, including latitude, x, y, long, etc. listed in the
http://mapserver.org/ogc/wcs_server.html#wcs-2-0-kvp-request-
parameters <http://mapserver.org/ogc/wcs_server.html#wcs-2-0-kvp-
request-parameters> , but GeoServer seems to not like it all.
What's the current correct format of specifying subset? I'm using GeoServer
2.8.
Thanks.
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
