On Fri, Oct 16, 2015 at 4:19 AM, Taeyun Kim <taeyun.kim@anonymised.com>
wrote:
The name ‘band’ cannot be used as a SQL viewparam name.
When used, rendering fails with the following exception:
net.opengis.wcs10.impl.AxisSubsetTypeImpl cannot be cast to java.lang.String
Maybe it is used by some other software layer’s keyword.
Is this intentional?
No, it's a side effect of how OGC style key/value pair requests are parsed
(in other words, all GET requests)
If so, can I see the list of reserved words that cannot be used as a SQL
viewparam name?
Basically any parameter name used in any OGC protocol is at risk. However I
cannot remember
why it got implemented that way, instead of just parsing a map of strings...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
