One of my users seems to have some issues adding a default gridset.
Geoserver answers the java stack trace attached to this email.
Is it a regression of version 2.3.3 as it wasn't a problem found in 2.3.2 ?
Emmanuel Lesouef
CRBN/DSI/SITI
t: 0231069671
e: e.lesouef@anonymised.com
geoserver_stack_trace.txt (11.7 KB)
Le Thu, 4 Jul 2013 17:35:05 +0200,
2.3.2 ?
May I put this issue back on this list as I don't know what to do to
deal with this.
Thanks.
Emmanuel Lesouef
If you’re sure it’s a bug and that the exact same thing didn’t happen in 2.3.2, it’s probably worth reporting it on the issue tracker:http://jira.codehaus.org/browse/GEOS
Jonathan
Is it a regression of version 2.3.3 as it wasn’t a problem found in
2.3.2 ?
May I put this issue back on this list as I don’t know what to do to
deal with this.
Thanks.
Emmanuel Lesouef
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Le Tue, 9 Jul 2013 13:01:10 +0100,
Jonathan Moules <jonathanmoules@anonymised.com> a écrit :
If you're sure it's a bug and that the exact same thing didn't happen
in 2.3.2, it's probably worth reporting it on the issue tracker:
Jonathan
Thanks for your answer.
It seems to me that I need to be a registered user to open a new issue
and that I need to contact an administrator to have an account.
Maybe there's another solution ?
Emmanuel Lesouef
Yep sorry; they’ve still not had that resolved it seems.
You can register here:
You can get an account here:
https://xircles.codehaus.org/signup/
Jonathan
Jonathan
Maybe there’s another solution ?
Emmanuel Lesouef
Le Tue, 9 Jul 2013 13:31:22 +0100,
Yep sorry; they've still not had that resolved it seems.
Jonathan
Thanks really much :
http://jira.codehaus.org/browse/GEOS-5880
Emmanuel Lesouef
