Here’s what I did at first on Windows and it worked:
Installed GeoServer from Platform Independent binary (just unzip install)
Start GeoServer using the provided start script appropriate for the platform
Use GDAL retile to create an image pyramid from a set of GeoTIFFs and output to a directory called “tiled”
In GeoServer web console create a new “Store” from the “tiled” directory
In GeoServer web console create a new layer from the newly created “Store”
In GeoServer view the layer through GeoServer “Layer Preview” and looks good
On Red Hat Linux the above steps also work.
On Suse Linux I followed the same steps as above but I get the below stacktrace at step 5:
(BTW: Here’s my Suse Linux version info:
Linux 3.0.101-0.5-default #1 SMP Thu Oct 31 05:21:34 UTC 2013 (36fae46) x86_64 x86_64 x86_64 GNU/Linux)
SUSE Linux Enterprise Server 11 (x86_64)
VERSION = 11
PATCHLEVEL = 2)
Oops, something went wrong…
Sorry, something unexpected happened on the server.
Here’s an error report you can include in a JIRA bug report about this issue:
java.lang.RuntimeException: Error occurred while building the resources for the configuration page
at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:307)
at org.geoserver.web.data.layer.NewLayerPage$6.onClick(NewLayerPage.java:242)
at org.geoserver.web.wicket.SimpleAjaxLink$1.onClick(SimpleAjaxLink.java:45)
at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:68)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.Exception: Unable to acquire test coverage for format:ImagePyramid
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:968)
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:855)
at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:297)
… 97 more
