Dear all ;
Im new here. IM following the tutorials. to continue with it i need to download the following data sets but the datasets links are not working. can some one post a proper link
http://docs.geoserver.org/1.7.x/user/getting-started/shapefile-quickstart/nyc_roads.zip
http://docs.geoserver.org/1.7.x/user/getting-started/postgis-quickstart/nyc_buildings.zip
best regards
deneth
As we are still working out some kinks in Sphinx, these files were not
automatically included in the HTML output. For the time being, you can
fetch them from the documentation sources in SVN:
http://svn.codehaus.org/geoserver/tags/1.7.4/doc/user/source/
The zip files you mentioned are at
http://svn.codehaus.org/geoserver/tags/1.7.4/doc/user/source/getting-started/shapefile-quickstart/nyc_roads.zip
and
http://svn.codehaus.org/geoserver/tags/1.7.4/doc/user/source/getting-started/postgis-quickstart/nyc_buildings.zip
respectively.
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Fri, 2009-05-22 at 10:48 +0530, deneth karunarathne wrote:
Dear all ;
best regards
deneth
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, &
iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Yep. I have already downloaded them thanks
On Fri, May 22, 2009 at 8:58 PM, David Winslow <dwinslow@anonymised.com> wrote:
and
respectively.
Hope this helps.
David Winslow
Dear all ;
best regards
deneth
