[Geoserver-users] Can't get bool field in Geoserver working with Openlayers
I added a datastore that points to a sql that has a bit field. If I view
the layer in geoserver I can see it is set as a Boolean under Feature Type
Details section.
I tried lots of things but if I try to insert a feature and populate the
boolean attribute value with anything from
1
true
True
t
It always comes back with the following error message Error performing
insert: Error inserting features.
If I manually insert a feature in sql and view the feature I can see that
the boolean attribute value comes back as "true" or "false", but if I now
try to save it again it will fail to save giving me the same error message
as above.
I am not sure what I'm doing wrong here.
Michael
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-t-get-bool-field-in-Geoserver-working-with-Openlayers-tp5214432.html
On Mon, Jul 6, 2015 at 1:52 PM, michael6779 <
michael.tang@anonymised.com> wrote:
Details section.
1
true
True
t
as above.
I might well be that you're doing nothing wrong, the JDBC driver in question
might be showing us the field as a "boolean" when we go though the metadata,
but then the database requires some specific syntax, like 1 or 0, when doing
an insert, while the existing code will take whatever you provide and turn
it into "true" and "false" (we never encode directly what we are given from
the client, that would be a major security risk, check "sql injection" if
you
the subject is new to you).
I'm sure that we don't natively handle "bit" fields for any database, you
might
want to create a request for improvement at
https://osgeo-org.atlassian.net/projects/GEOS,
specifying the details of your database and a create table that can be
used to reproduce the issue.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
