[Geoserver-users] Can't project Image Mosaic from 900913 to 4326
Hello,
Geoserver ver. 2.3.4
I have got an Image Mosaic with about 10 Geotiffs (inner tiling, overviews), all in all about 1 GB, they are all in EPSG 900913 (web mercator).
When I try to view them in WGS84 (EPSG 4326), I get nothing or pink tiles and the following error:
2013-12-19 07:55:09,266 WARN [geotools.rendering] - Requested region cannot be represented by a single Raster.
java.lang.IllegalArgumentException: Requested region cannot be represented by a single Raster.
at javax.media.jai.PlanarImage.getData(PlanarImage.java:2163)
at javax.media.jai.RenderedOp.getData(RenderedOp.java:2276)
at sun.java2d.SunGraphics2D.drawRenderedImage(SunGraphics2D.java:2615)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.paint(GridCoverageRenderer.java:923)
at org.geotools.renderer.lite.StreamingRenderer$RenderRasterRequest.execute(StreamingRenderer.java:3487)
at org.geotools.renderer.lite.StreamingRenderer$PainterThread.run(StreamingRenderer.java:3590)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Afterwards, I can still access the web interface, but all requests return pink tiles an I have to restart geoserver.
When I try to project the single geotiffs, I do not encounter this problem.
Any ideas?
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
That sounds like a fairly bad bug (in ImageMosaic?) - especially if all future requests to GeoServer return pink tiles. I’d suggest reporting it on JIRA.
Jonathan
On 19 December 2013 08:11, Nikolaus Pruzsinszky <n.pru@anonymised.com> wrote:
Hello,
Any ideas?
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
