After a full disk issue, we made more room and rebooted. Tomcat starts up fine, but geoserver will not start. This GS instance has a lot of ascii grids served as out as pngs. Most of the error log seems to load layers OK, then it dies. The end off the error log is attached.
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
Your log shows geoserver having a hard time, unable to load:
geoserver
dispatcher
workspaceLocal
One thing to do is temporarily move your data directory out of the way and confirm GeoServer starts up with the default set of layers. This will ensure your installation works, prior to recovering your layers.
You can also look at editing your data directory, disabling each store in the hopes of getting it to start up (and then turning them on one by one to determine where the problem is).
Steve
Stephen Crawford
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now. http://p.sf.net/sfu/bds
- shut down tomcat
- make sure the user used to run Tomcat has correct privileges on the data dir
- change log level to verbose (you can edit the logging.xml file in
the data dir, see attache file)
- clean tmp and work directory for tomcat
- restart
If it works than we are done, otherwise send over the _full_ log
Simone Giannecchini
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Simone Giannecchini @simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Jul 17, 2014 at 10:20 PM, Stephen Crawford <src176@anonymised.com> wrote:
Hello All,
Steve
Stephen Crawford
Code Sight - the same software that powers the world's largest code
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
