I've managed to do something odd to my installation of GeoServer (2.1.3, installed some time in the last twelve months).
I appear to have created two installations and have lost control of one of them - I've just uninstalled the one with the intention of re-installing an newer version. But one of the installations is still present. I can't find a way to stop it and therefore can't simply delete the files.
Can someone tell me the name of the processes to look for on the server to force a shut-down? I can then start again!
Dave
David Slade
Senior IT and Records Officer,
South East Wales Biodiversity Records Centre,
13 St Andrews Crescent,
Cardiff
CF10 3DB
Tel: 029 2064 1110
Fax: 029 2038 7354
Email: david.slade@anonymised.com
www.sewbrec.org.uk
Find us on Facebook: http://www.facebook.com/SEWBReC
Follow us on Twitter: http://twitter.com/SEWBReC
Hi David,
On windows its a “java.exe” that’s a sub-item for “cmd.exe”, at least if you’ve used the batch file to start it.
If its a service I’m not sure what it’ll be. Use the excellent Process explorer to find out what’s running - http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx - also it may be running as a different user?
Jonathan
On 6 February 2013 09:19, David Slade <david.slade@anonymised.com> wrote:
I’ve managed to do something odd to my installation of GeoServer (2.1.3,
of them - I’ve just uninstalled the one with the intention of
present. I can’t find a way to stop it and therefore can’t simply delete
the files.
Dave
David Slade
Cardiff
CF10 3DB
Tel: 029 2064 1110
Fax: 029 2038 7354
www.sewbrec.org.uk
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013
and get the hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
