Anyone knows if it’s possible to use WFS 2.0 as a data source (cascading WFS) in GeoServer? Seems that at least parsing WFS 2.0 capabilities document is not supported: “Error creating data store, check the parameters. Error message: Expected {http://www.opengis.net/wfs}WFS_Capabilities but was http://www.opengis.net/wfs/2.0#WFS_Capabilities”
On Wed, Mar 20, 2013 at 8:57 AM, Matti Silvennoinen
<matti.silvennoinen@anonymised.com> wrote:
message: Expected {http://www.opengis.net/wfs\}WFS_Capabilities but was
The WFS data store allowing for WFS cascading indeed supports WFS 1.1
and WFS 1.0
only.
I'm not aware of short term plans to build a WFS 2.0 client into it.
Maybe you can help?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea. Let's see if we can help in that..
Matti
-----Original Message-----
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 20. maaliskuuta 2013 10:33
To: Matti Silvennoinen
Subject: Re: [Geoserver-users] Cascading WFS 2.0 in GeoServer
On Wed, Mar 20, 2013 at 8:57 AM, Matti Silvennoinen <matti.silvennoinen@anonymised.com5501...> wrote:
Anyone knows if it's possible to use WFS 2.0 as a data source
(cascading
document is not supported: "Error creating data store, check the
parameters. Error
http://www.opengis.net/wfs/2.0#WFS_Capabilities"
The WFS data store allowing for WFS cascading indeed supports WFS 1.1 and WFS 1.0 only.
Maybe you can help?
Ing. Andrea Aime
@geowolf
Technical Lead
matti.silvennoinen@
document
and WFS 1.0
only.
Maybe you can help?
Andrea, you probably have some idea how much work it would take
to add the WFS 2.0 cascading support to GeoServer? Can you give
some details what needs to be changed and where can I find
those parts in the (2.4-SNAPSHOT) source code?
Best wishes,
Juhani
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cascading-WFS-2-0-in-GeoServer-tp5041596p5062262.html
On Wed, Jun 26, 2013 at 10:37 AM, juhanisaastamoinen <
You basically have to add WFS 2.0 support to the GeoTools WFS data store
here:
https://github.com/geotools/geotools/tree/master/modules/unsupported/wfs
That's quite a bit of work, I guess you can follow the WFS 1.1 code and
mimick it to generate
a 2.0 version
Ing. Andrea Aime
@geowolf
Technical Lead
Hello all
I'm checking if the situation is still the same? WFS 2.0 support for WFS
store is not yet implemented?
best regards
Roope
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cascading-WFS-2-0-in-GeoServer-tp5041596p5102016.html
On Wed, Feb 5, 2014 at 11:10 AM, roopetervo <roope.tervo@anonymised.com> wrote:
Hello all
Correct, not implemented yet.
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
