[Geoserver-users] cascading wms and native crs
Hello.
I am trying to add my non-GeoServer WMS as a cascaded WMS to GeoServer. However, the detected SRS is not correct. GeoServer detect EPSG:3575, but EPSG:4326 would be a better fit.
This is the WMS URL I am trying to add. Layer coverage.
http://services.ecc.no/wms/wms_ip/anonymous
How does GeoServer detect the native SRS of a cascaded WMS? It looks like CatalogBuilder#buildWMSLayer loops the bounding boxes of the layer, but this WMS has bounding boxes for several SRSs.
My first guess was that GeoServer used the SRS-element of each Layer i capabilities, but that did not help (I have updated my development server with this attempt).
Tore Halset.
Hi Tore,
yeah, by looking at the code it seems it ends up picking the last one that it can understand, among the published ones.
I believe the original intention was to actually pick the first one, but we forgot to add a “break;”
That said, the spec does not seem to provide a way to identify the “native” one, it just says:
On Sat, Sep 27, 2014 at 11:49 AM, Tore Halset <halset@…6696…> wrote:
Hello.
Tore Halset.
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi.
Thank you for the answer. The problem occurs when the different CRSs has different bounding boxes and GeoServer select one CRS that is valid for a smaller area than other CRSs and the actual data. As an example, this WMS has world coverage in EPSG:4326, but EPSG:3575 is only valid for the northern hemisphere.
- Tore.
On Mon, Sep 29, 2014 at 8:41 AM, Tore Halset <halset@anonymised.com> wrote:
Hi.
Ah, I see, the bbox is cut to each area domain of validity.
We could back transform each bbox to wgs84 and pick the largest one, yet,
the reprojection itself back and forth can make bboxes larger each way one
goes around (because of the rotation and the fact that the tilted
reprojected
bbox is turned into another axis parallel bbox), so reprojected bboxes
migth look larger than a "original" wgs84 one.
I'm leaning towards keeping things simple and just pick the first bbox in
the
list. Would that work in your case?
Ing. Andrea Aime
@geowolf
Technical Lead
goes around (because of the rotation and the fact that the tilted reprojected
I'm leaning towards keeping things simple and just pick the first bbox in the
Picking the first is fine for me as I can tune the capabilities myself. However, choosing the box for EPSG:4326 would be a more logical (IMO) choice. And layer.getBoundingBoxes() return a HashMap, so we will have to dig a bit deeper to find the *first* than just adding a “break;”.
Tore Halset.
