This page of the documentation - http://docs.geoserver.org/stable/en/user/datadirectory/data-dir-structure.html - says there’s a catalog.xml file, and makes reference to it in both the /data/ and /styles/ section. However I can’t find any such file in either my data directory or my geoserver-install directory.
Does anyone know if there is still a catalog.xml or is it something that has been deprecated?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
