[Geoserver-users] Certain database layer configs not loading after upgrade from 2.2.5 to 2.4.2. Please help!
Geoserver 2.4.2
Windows Server 2008 R2 64Bit
Java 1.7.0_15 (Java HotSpot™ 64-Bit Server VM)
Last night I upgraded Geoserver to 2.4.2 from 2.2.5 to see if that would resolve an issue we had with it failing intermittently, however this has made things significantly worse and I wonder if this situation might sound familiar to anyone?
We have several hundred layers configured, most of them are Oracle based layers and most of them appear to work fine. The problem is that some are not showing in Geoserver as configured layers at all. I have a workspace and datastore combination that should have about 30 Oracle based layers but only shows 7 of them. The 7 that are there work perfectly, I can get maps using WMS no problem. The next obvious step was to add them back in and here’s where it gets more interesting. Clicking add layer shows that Geoserver thinks the layer has already been added, in fact, all the missing ones are marked as already having been published and it won’t let me add them again with the same names because it knows they’re already there. For each of the missing layers there is a folder in the data directory with an apparently sound looking featuretype.xml and layer.xml.
Next thing I tried was to delete the existing folder, reload the Geoserver configs and get Geoserver to recreate it by re adding the layer. Doing that gives me a layer that works. Geoserver will render it using WMS etc and I can even assign a new default style to it via REST. The folder is created with a new featuretype.xml and layer.xml and all looks great. Problem is that as soon as I restart Geoserver that layer is no longer loaded and no longer responds to WMS requests etc. In fact, we’re back to exactly where we started in all respects. Geoserver knows it’s there because it won’t let me create a layer with the same name but I can again, fool it by deleting the layer folder and starting again.
Another thing I tried a this stage was making a minor manual edit to the featurelayer.xml file to change the title. Despite it being a text only change that also caused the layer to stop working and vanish from the list of configured layers (but remain in the list of published ones for the purposes of adding new layers)
There are tens of layers for which this is an issue and it would appear that even if I go through and fix them all manually they’re not going to persist through a Geoserver restart.
I wondered if it was a Windows permissions thing but the service is running as an administrator user and is the creator for the new folders so should surely be able to read them back again?
Even more frustratingly rolling back to 2.2.5 doesn’t help as that now completely fails to load.
The only other clue I can find is that Geoserver reports lots of errors on startup. One layer I’ve been looking into specifically is mentioned and the error log is included at the bottom of this message. There are lots of this specific error. There doesn’t appear to be anything more generic, just lots of layer specific startup errors.
Any ideas?
Thanks in advance,
Tom
The error:
2013-12-18 08:01:22,861 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer PENDLELAYER363
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1252)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:218)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Almost forgot… There’s an error also on the preview page in the admin console, i.e. click “layer preview” in the menu and I get this:
org.apache.wicket.WicketRuntimeException: Can’t instantiate page using constructor public org.geoserver.web.demo.MapPreviewPage() at org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:212) at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:57) at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.newPage(BookmarkablePageRequestTarget.java:298) at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.getPage(BookmarkablePageRequestTarget.java:320) at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.processEvents(BookmarkablePageRequestTarget.java:234) at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173) at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206) at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:324) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) at java.lang.reflect.Constructor.newInstance(Unknown Source) at org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:192) … 93 more Caused by: java.lang.NullPointerException at org.geoserver.ows.LocalWorkspaceCatalogFilter.hideResource(LocalWorkspaceCatalogFilter.java:53) at org.geoserver.security.CatalogFilterAccessManager.hideResource(CatalogFilterAccessManager.java:95) at org.geoserver.security.CatalogFilterAccessManager.getAccessLimits(CatalogFilterAccessManager.java:49) at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:793) at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:584) at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:478) at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:631) at org.geoserver.security.SecureCatalogImpl.filterGroups(SecureCatalogImpl.java:946) at org.geoserver.security.SecureCatalogImpl.getLayerGroups(SecureCatalogImpl.java:310) at org.geoserver.catalog.impl.AbstractFilteredCatalog.getLayerGroups(AbstractFilteredCatalog.java:248) at org.geoserver.catalog.impl.AbstractCatalogDecorator.getLayerGroups(AbstractCatalogDecorator.java:456) at org.geoserver.catalog.impl.LocalWorkspaceCatalog.getLayerGroups(LocalWorkspaceCatalog.java:197) at org.geoserver.web.demo.PreviewLayerProvider.getItems(PreviewLayerProvider.java:69) at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:236) at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:562) at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:555) at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:219) at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:98) at org.geoserver.web.demo.MapPreviewPage$1.(MapPreviewPage.java:63) at org.geoserver.web.demo.MapPreviewPage.(MapPreviewPage.java:63) … 98 more
On Wed, Dec 18, 2013 at 8:31 AM, Tom (JDi Solutions) <tom.dean@anonymised.com> wrote:
Geoserver 2.4.2
Any ideas?
Thanks in advance,
Tom
The error:
I have managed to sort this by restoring the data directory from a backup, uninstalling Geoserver and installing a fresh 2.3.5 instance.
All I can think might have happened now is that I may have inadvertently had two Geoserver services running at the same time when I initially did the upgrade and perhaps that messed up the data directory somehow.
On Wed, Dec 18, 2013 at 8:58 AM, Tom (JDi Solutions) <tom.dean@anonymised.com> wrote:
Geoserver 2.4.2
Any ideas?
Thanks in advance,
Tom
The error:
