[Geoserver-users] CH1903/LV03 Spatial Referencing System
Hello
I have a problem to create a FeatureType with my data. The data stored
in a shape file and in CH1903/LV03 as Spatial Referencing System. This
is a swiss coordinate system. So I tried with SRS 21780, 21781, 4149
and 4150 with no solution.
How can help? If there a (transformation) problem on side of geoserver
or will I made something wrong?
Thank you.
Regards, Thomas
PS. The same shape file will be correct and shown with uDig.
Thomas Zuberbuehler
http://www.zubi.li
Gruezi
Do you only use CH1903/LV03 coordinates or you want to
mix them with another Referencing System?
Ciao
Patrick
Hello
Thank you.
Regards, Thomas
Thomas Zuberbuehler
http://www.zubi.li
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Hello Everybody.
I tried it also with SRS 2056 and 480, thus all named with CH1903.
With SRS 2056 the data are shown, but around approximately 45 degrees
the counterclockwise. It is always the same, either the coordinates
are wrongly transformed (for example -17/-85 for an area in Europe!)
or simply 0/90.
Who can help? What wrong do I make?
Thank you.
Thomas
2006/10/27, Thomas Zuberbuehler <tzuberbuehler@anonymised.com>:
Hello
Thank you.
Regards, Thomas
Thomas Zuberbuehler
http://www.zubi.li
Thomas Zuberbuehler
http://www.zubi.li
Do you have the well known text for your srs? It seems like it should be a standard one already in the database, but you can add it - instrucions here: http://docs.codehaus.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver (though I think the second set is now the standard way).
It's odd that it works properly in udig and not geoserver, as they use the same code. Maybe you can see the epsg code in there, and then you have to fill it out properly in GeoServer?
Chris
Thomas Zuberbuehler wrote:
Hello Everybody.
or simply 0/90.
Thank you.
Thomas
Hello
Thank you.
Regards, Thomas
Thomas Zuberbuehler
http://www.zubi.li
Chris Holmes
The Open Planning Project
http://topp.openplans.org
