[Geoserver-users] Chaining Render Transformations: InvalidParameterException
Dear Geoserver Users,
I’m trying to display contours coming from a Barnes surface interpolation. The Interpolated Surfaces works well stand-alone, but the chaining into the contour extraction does not work.
My SLD looks like this:
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version=“1.0.0”
xsi:schemaLocation=“http://www.opengis.net/sld StyledLayerDescriptor.xsd”
xmlns=“http://www.opengis.net/sld
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xlink=“http://www.w3.org/1999/xlink
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”>
Barnes surface contours
Barnes Surface contours
A style that produces a Barnes surface using a rendering transformation
<ogc:Function name=“gs:Contour”>
<ogc:Function name=“parameter”>
ogc:Literaldata</ogc:Literal>
<ogc:Function name=“gs:BarnesSurface”>
</ogc:Function>
ogc:LiteralvalueAttr</ogc:Literal>
ogc:Literalbewertung_bo_wert</ogc:Literal>
</ogc:Function>
ogc:Literalscale</ogc:Literal>
ogc:Literal1000</ogc:Literal>
</ogc:Function>
ogc:Literalconvergence</ogc:Literal>
ogc:Literal0.8</ogc:Literal>
</ogc:Function>
ogc:Literalpasses</ogc:Literal>
ogc:Literal3</ogc:Literal>
</ogc:Function>
ogc:LiteralminObservations</ogc:Literal>
ogc:Literal1</ogc:Literal>
</ogc:Function>
ogc:LiteralmaxObservationDistance</ogc:Literal>
ogc:Literal10000</ogc:Literal>
</ogc:Function>
ogc:LiteralpixelsPerCell</ogc:Literal>
ogc:Literal10</ogc:Literal>
</ogc:Function>
ogc:LiteralqueryBuffer</ogc:Literal>
ogc:Literal40</ogc:Literal>
</ogc:Function>
ogc:LiteraloutputBBOX</ogc:Literal>
<ogc:Function name=“env”>
ogc:Literalwms_bbox</ogc:Literal>
</ogc:Function>
</ogc:Function>
ogc:LiteraloutputWidth</ogc:Literal>
ogc:Literalwms_width</ogc:Literal>
</ogc:Function>
</ogc:Function>
ogc:LiteraloutputHeight</ogc:Literal>
ogc:Literalwms_height</ogc:Literal>
</ogc:Function>
</ogc:Function>
</ogc:Function>
ogc:Literallevels</ogc:Literal>
ogc:Literal-20</ogc:Literal>
ogc:Literal-15</ogc:Literal>
ogc:Literal-10</ogc:Literal>
ogc:Literal-5</ogc:Literal>
ogc:Literal0</ogc:Literal>
ogc:Literal5</ogc:Literal>
ogc:Literal20</ogc:Literal>
</ogc:Function>
</ogc:Function>
</ogc:Function>
rule1
Isotherm
#000000
1
<ogc:Function name=“round”>
ogc:PropertyNamevalue</ogc:PropertyName>
</ogc:Function>
Arial
Normal
12
ogc:Literal2</ogc:Literal>
#FFFFFF
0.6
#000000
2000
true
100
50
30
I get the following exception:
Caused by: java.security.InvalidParameterException: Could not convert the value [GridCoverage2D[“Process Results”, GeneralEnvelope[(4426557.1796875, 5312865.4335937), (4491521.1796875, 5364506.7382812)], DefaultProjectedCRS[“DHDN / 3-degree Gauss-Kruger zone 4”]]
? RenderedSampleDimension(“Process Results”:[-999 … 10])
? ? GeophysicsCategory(“Process Results”:[-999.0 … 10.137810707092171])
? GeophysicsCategory(“No data”:[NaN(0…0)])
? Image=WritableRenderedImageAdapter
, {levels=[-20, -15, -10, -5, 0, 5, 20]}] into the expected type class org.geotools.coverage.grid.GridCoverage2D for parameter data
at org.geotools.process.function.ProcessFunction.evaluateInputs(ProcessFunction.java:198)
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:103)
at org.geotools.renderer.lite.StreamingRenderer.applyRenderingTransformation(StreamingRenderer.java:2224)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1984)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:814)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:490)
This message says it cannot convert a GridCoverage2D into a GridCoverage2D – strange?
Any idea what could help here?
I’m running Geoserver 2.2.0 with the corresponding WPS module in a Java6 environment.
Kind regards,
Sebastian Schmidt
SWM -Besser leben mit M.
Informations- und Prozesstechnik
Anwendungen Technische Geschäftsfelder
Telefon: 089/23 61-44 78
Telefax: 089-2361-70 44 78
schmidt.sebastian2@anonymised.com
www.swm.de
SWM Services GmbH, Emmy-Noether-Straße 2, 80992 München; Geschäftsführer Dr. Florian Bieberbach, Herbert König, Reinhard Büttner, Stephan Schwarz, Erna-Maria Trixl; Sitz München; Registergericht München HRB 126 674; Aufsichtsratsvorsitzender Oberbürgermeister Christian Ude
Der Inhalt dieser E-Mail oder eventueller Anhänge ist ausschließlich für den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in Verbindung zu setzen.
2013/6/6 <Schmidt.Sebastian2@anonymised.com>
Strange indeed,
but I also remember that transformation chaining was problematic in 2.2.0.
It seems that in 2.3.x there are still issues, but in this report the user states he can chain
Barnes surfaces with countour with no issues (while chaining Barns and point extraction apparently
does not):
http://jira.codehaus.org/browse/GEOS-5741
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
