Hello everyone,
I'm just wondering if it's possible to change the format that Geoserver uses
to parse the date from a database (in my case postgresql with postgis
extension).
From browsing the mailinglist I found out that it uses this method to parse
dates:
SimpleDateFormat format = (SimpleDateFormat)DateFormat.getInstance();
So is it possbile to tell Geoserver a certain format like:
SimpleDateFormat sdf = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss"), which is
also used in postgresql?
I'm trying to retrieve data from the backend posgresql database via
Geoserver's WFS service within a certain time period. Therefore Geoserver
has to compare my inputed timestamps with the ones in the database. When
Geoserver reads then the dates from postgresql, I get the following
execption:
java.text.ParseException: Unparseable date: "2001-02-11T20:03:00Z"
at java.text.DateFormat.parse(DateFormat.java:337)
I need to change the format in Geoserver, because - as I understand - I
can't change the format that postgresql uses to save the dates.
Thanks in advance!
Best regards, Thalles
View this message in context: http://www.nabble.com/Change-date-format-tp23924131p23924131.html
Thalles ha scritto:
Hello everyone,
extension).
dates:
execption:
Can you provide a full stack trace? As far as I know the code that
reads from the database does not do string parsing, it uses:
resultset.getObject(position);
which will return a java.util.Date. So the issue must be happening
somewhere else.
Andrea Aime
OpenGeo - http://opengeo.org
here is the full stack trace:
java.text.ParseException: Unparseable date: "2001-02-11T20:00:14Z"
at
uk.ac.york.cs.kmlservlet.constants.ConstantsAdvanced.getDateFromString(ConstantsAdvanced.java:115)
at
uk.ac.york.cs.kmlservlet.model.TrackGeneralized.<init>(TrackGeneralized.java:52)
at uk.ac.york.cs.kmlservlet.kml.kmlmode.KMLMode.getTracks(KMLMode.java:59)
at
uk.ac.york.cs.kmlservlet.kml.kmlmode.TrackOverview.getKML(TrackOverview.java:43)
at uk.ac.york.cs.kmlservlet.KMLServlet.doGet(KMLServlet.java:123)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
View this message in context: http://www.nabble.com/Change-date-format-tp23924131p23926982.html
Thalles ha scritto:
at
at
at
Hum... this is in your code, not in GeoServer. Maybe I did not
understand your original question? The date above is correct and
specified according to the ISO standard.
Andrea Aime
Yeah, also saw that it was my code producing the execption after I posted it.
I think I know how to solve it!
Thanks anyway for your help!
Bye Thalles
View this message in context: http://www.nabble.com/Change-date-format-tp23924131p23927286.html
