change number of Results per page, from the screen shot of the document, it seems like every page will show 10 records, but mine is showing 50 records per page.
Where is the setting? I didn’t find this in the document.
The results of what? My “layer preview” page has 25 results, as does my list of layers and adding a new layer.
Using 2.2.3.
Would be a neat idea to be able to change that number though; does anyone know if this can be done?
Jonathan
Master HTML5, CSS3, ASP.NET, MVC, AJAX, Knockout.js, Web API and
much more. Get web development skills now with LearnDevNow -
350+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only – learn more at:
http://p.sf.net/sfu/learnmore_122812
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
The number of results per page is 50. I want change it to 10
Using 2.2.3.Would be a neat idea to be able to change that number though; does anyone know if this can be done?
Jonathan
https://lists.sourceforge.net/lists/listinfo/geoserver-usersThis transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Fri, Jan 18, 2013 at 11:53 AM, Jonathan Moules <jonathanmoules@…4942…> wrote:
The number is hard coded, no way to configure it at present, but
it could be easily made globally configurable.
Configurable per logged in user, uh, that would be harder, we don’t
have a notion of per user preferences.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
You refer to the maxFeatures=50 present in the WFS sample requests?
That’s also hard coded
Ing. Andrea Aime
@geowolf
Technical Lead
