Andrea,
Thank you for your time and response!
Yes, please provide the links you mentioned below if you have the time. I would like to forward your response to me team.
My investigation revealed the same. I felt the only way to remove the support of unwanted spatial operators would be a code change. Your response confirmed my suspicions.
Thank you again for your time!
Jeff W.
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Friday, September 18, 2015 10:12 PM
To: jwells1@anonymised.com
Cc: GeoServer Mailing List List geoserver-users@lists.sourceforge.net; Change@anonymised.com
Subject: Re: [Geoserver-users] (no subject)
On Thu, Sep 17, 2015 at 12:02 AM, jwells1@anonymised.com <jwells1@anonymised.com> wrote:
Hello,
I am currently working with GeoServer 2.1.1.7 war file which is hosted on
Apache Tomcat 7.0.64 and running on RHE x86_64.I researched my question in the user’s mailing list however I did not find
the answer. I apologize if it exists and I overlooked it.My question is whether it is possible to modify the WFS GetCapabilites in
such a way that the operators that are not supported in our environment
would not be displayed.For example, the spatial operators “Disjoint” and “Equals” will not be
supported. Our users will not need to use these operators so is there a
way
to remove them from the GetCapabilities Spatial Operators list?
The non written rule is that stores need to support all operators, and
emulate in memory the ones they don’t have, all official stores do that,
it’s not difficult (I can provide links if you want an example).
Would this
require a code change and re-compiling of the code or is there a way to
eliminate these operators without a code change?
Code change would be the only way as far as I know, if you really
don’t want the in-memory emulation
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
