Having recently switched from Geoserver 2.5.0 to 2.5.1, we have become aware of an unfortunate change in the way the WMS renders rasters. We have a postgis vector database with topographic data. As backdrop, we use the image mosaic
plugin with hillshades tiles.
In 2.5.0, the hillshades where easy to render smoothly (despite a relative course resolution) by adjusting the WMS default raster rendering interpolation from “Nearest neighbor” to “Bilinear” or “Bicubic”. Transferring the same setup to 2.5.1, changing
the interpolation method has no effect any more, “Nearest neighbor” (or, perhaps no interpolation at all) seems to be used no matter what setting we use, rendering nasty pixel borders on the innermost zoomlevels.
We’ve done some testing with different versions, and it seems that changing the interpolation worked fine in 2.4.6, failed in 2.4.7, worked fine again in 2.5.0 and failed again in 2.5.1 and all later versions including 2.6 beta.
The image mosaic tiles have the same resolution, bit depth and coordinate system (EPSG:3857). Asking the WMS in another coordinate system is not relevant to this problem, as it occurs in 3857 as well.
Here’s a comparison of the same area. 2.5.1 vs 2.5.0, both set to use bilinear interpolation:
Hi Hans,
I’d advise reporting this one as a bug to JIRA. It seems like a regression in 2.5.1.
Might also be worth testing 2.6 before they finalise.
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 14 August 2014 09:15, Hans Gunnar Steen <hans.gunnar.steen@anonymised.com> wrote:
Kind regards Hans
Geoserver-users mailing list
