[Geoserver-users] Changing GEOSERVER_DATA_DIR problem
Hello
I have GeoServer 2.4.1 installed on Windows Server 2008 R2 in a Tomtcat 7.0 container. I am trying to change the location of the GEOSERVER_DATA_DIR but I am losing all the configurations (layers, datasources, workspaces, etc) when doing so. The GEOSERVER_DATA_DIR parameter in the web.xml is commented out and instead a Windows environment variable has been created that points to a location in the local disk drive. The steps that I have been doing are:
  1. Copy the entire folder that contains the GEOSERVER_DATA_DIR to the new target location.
  2. Change the GEOSERVER_DATA_DIR Windows environment variable from the current location to the new desired one.
  3. Restart Tomtcat 7.0 service.
When I log on to GeoServer, I find that all the configuration has been deleted and instead I get the default workspaces, layers, etc that come by default with GeoServer!
What am I doing wrong? Any solutions for this problem?
Ammar
Hi Ammar,
if you have installed Tomcat as a Windows service I suggest to set the GEOSERVER_DATA_DIR
inside your service properties → Java → Java Options. I hope this can help you.
Tobia Di Pisa
Dott. Ing. Tobia Di Pisa
Software Engineer
Via Poggio alle Viti 1187
Call
Send SMS
Add to Skype
You’ll need Skype CreditFree via Skype
2014-10-08 12:50 GMT+02:00 Ammar <ammar83_h@anonymised.com>:
Hello
Ammar
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Tobia,
Thanks for your reply. I am afraid I don’t quite understand what you mean! The Tomtcat is in fact installed as a Windows Server but I can not see any Java options in its properties!
Ammar
To: Ammar ammar83_h@anonymised.com
Cc:geoserver-users@lists.sourceforge.netgeoserver-users@lists.sourceforge.net
Sent: Wednesday, October 8, 2014 2:08 PM
Subject: Re: [Geoserver-users] Changing GEOSERVER_DATA_DIR problem
Hi Ammar,
Tobia Di Pisa
Software Engineer
Call
Send SMS
Add to Skype
Hello
Ammar
Hi Ammar,
if you have created a windows service you can edit this using the command below:
{your_tomcat_path}\bin\tomcat7w //ES/{your_service_name}
here some useful documentation about that.
Tobia Di Pisa
Software Engineer
Call
Send SMS
Add to Skype
2014-10-08 15:06 GMT+02:00 Ammar <ammar83_h@anonymised.com>:
Hi Tobia,
Ammar
To: Ammar <ammar83_h@anonymised.com.>
Cc:geoserver-users@lists.sourceforge.net” <geoserver-users@anonymised.comeforge.net>
Hi Ammar,
Tobia Di Pisa
Software Engineer
Call
Send SMS
Add to Skype
Hello
Ammar
