[Geoserver-users] Changing polygon label's font in the SDL
Hi, I have a polygon layer that works perfectly. But I'm trying to change the
font-family as it's here
http://docs.geoserver.org/latest/en/user/styling/sld-reference/textsymbolizer.html#font
<http://docs.geoserver.org/latest/en/user/styling/sld-reference/textsymbolizer.html#font&gt;
but it doesn't make any difference. This is a portion of my sdl doc:
        <http://osgeo-org.1560.x6.nabble.com/file/n5087659/Captura.png&gt;
I also want to know, if there is a directory where I can place my custom
fonts or if there is some documentation about it.
Thank you very much!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Changing-polygon-label-s-font-in-the-SDL-tp5087659.html
The following works for me (this is SLD 1.1). Not sure about custom directories etc.
se:TextSymbolizer
se:Label
ogc:PropertyNameTEXTSTRING</ogc:PropertyName>
</se:Label>
se:Font
<se:SvgParameter name=“font-family”>Calibri</se:SvgParameter>
<se:SvgParameter name=“font-size”>
ogc:Mul
ogc:Literal2</ogc:Literal>
ogc:Add
ogc:Literal3</ogc:Literal>
ogc:PropertyNameHEIGHT</ogc:PropertyName>
</ogc:Add>
</ogc:Mul>
</se:SvgParameter>
<se:SvgParameter name=“font-style”>normal</se:SvgParameter>
<se:SvgParameter name=“font-weight”>normal</se:SvgParameter>
</se:Font>
se:LabelPlacement
<se:LinePlacement />
</se:LabelPlacement>
se:Fill
<se:SvgParameter name=“fill”>#111111</se:SvgParameter>
</se:Fill>
</se:TextSymbolizer>
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 6 November 2013 14:57, beldar15 <beldar15@anonymised.com> wrote:
Hi, I have a polygon layer that works perfectly. But I’m trying to change the
font-family as it’s here
<http://docs.geoserver.org/latest/en/user/styling/sld-reference/textsymbolizer.html#font>
but it doesn’t make any difference. This is a portion of my sdl doc:
<http://osgeo-org.1560.x6.nabble.com/file/n5087659/Captura.png>
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
I think the font is case-sensitive so “Courier” instead of “courier”
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Direct (719) 452-7257
Description: Description: Description: cid:image001.png@anonymised.com
se:TextSymbolizer
se:Label
</se:Label>
se:Font
ogc:Mul
ogc:Add
</ogc:Add>
</ogc:Mul>
</se:SvgParameter>
</se:Font>
se:LabelPlacement
se:Fill
</se:Fill>
