[Geoserver-users] charSet Settings will be ignored
Hi Andrea,
I change the settings in service.xml from UTF-8 to ISO-8859-15.
I restart my Apache-Tomcat or press the "Load"-Button.
I use the Probe Requests Sample for WFS GetFeature Version 1.0 and 1.1.
Both XML-Files have got <?xml version="1.0" encoding="UTF-8"?> instead of
<?xml version="1.0" encoding="ISO-8859-15"?>.
I have got the same problem with the Capabilities-Document.
Tim
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet: Dienstag, 18. März 2008 09:31
An: Tim Englich
Betreff: Re: [Geoserver-users] charSet Settings will be ignored
Tim Englich ha scritto:
Hello List,
I have got Problems setting up Geoserver 1.6.2 to produce XML-Files which
have got another Encoding than UTF-8.
I version 1.5 I could do this by changing the <charSet value =
"ISO-8859-15"
/> Element in the File Services.xml.
In Geoserver 1.6.2 changing the Value has got no Effect.
Has anyone an Idea how to solve this Issue?
Hum, can you make me an example? Is all output wrong, or just GML3, or KML?
Hi Andrea,
Hum, yes, I checked, it seems that kind of support has been systematically removed from all xml encodings... and I don't
know why. Yet I have the impression the charset was declared,
but not always properly set in the output stream used for encoding
the capabilities, so it may be that the outputs weren't completely
correct in 1.5.x either?
I just don't remember wheter the default encoding is the platform
one or if it's UTF-8.
Maybe Justin knows more.
Confirmed bug / regression. Created a jira for it:
http://jira.codehaus.org/browse/GEOS-1815
-Justin
Tim Englich wrote:
Hi Andrea,
Tim
An: Tim Englich
Hello List,
"ISO-8859-15"
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4007,47dfbde2201101439371379!
