I am looking for a GeoServer symbolizer to produce scaled pie charts.
When I search for Geoserver chart, the first result I get is https://geoserver.geo-solutions.it/edu/en/pretty_maps/charting.html It refers to Eastwood Charts, which appears to be a project last touched 12 years ago. Is this the code used by the official extension: Chart Symbolizer or is it now included inside GeoServer? Is this extension actively maintained?
Is this the preferred charting solution? I see it referenced in a number of SO answers.
Andrea/GeoSolutions, would it be acceptable to add a link to the extensions page above linking to your website, or would it be better to copy that charting.html page into the GeoServer documentation? If so, I could do it with your permission.
How do you plan to deliver the map ? If you use OpenLayers, you can perhaps try to use the chart style provided by ol-ext (https://viglino.github.io/ol-ext/).
Thanks Alexandre. I have considered OpenLayers, or preferably Leaflet, but the intension is to render it in GeoServer (to protect the raw data) unless there are very definite reasons not to use the Chart extension.
Regards
Alexandre
Le jeu. 2 avr. 2020 à 16:41, Peter Smythe <gs@anonymised.com> a écrit :
Hi all
Thank you
Peter
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
I would just say that I recently installed and used the chart extension for pie charts and found it worked well whatever the age of the code. I got the extenson from
but obviously you would need to get for your version of geoserver.
Hi all
