[Geoserver-users] Chloropleth legend printing
Hello,
I am using the MapFish printing plugin (print-lib-2.0-SNAPSHOT-20140410) with GeoServer 2.5.1.
When I try to print a chloropleth layer with multiple symbols based on values, the entry for that layer in the legend is too small. A PDF with the small legend entry is at https://unomaha.box.com/s/8qfxjyhrx9reaaotq7q2. My config is at http://pastebin.com/c3D5nbGh
Is there anything I can fix on my end?
Thank you!
Bettina
blechner@…6560…
Hi Bettina,
usually a maxIconHeight: 0 setting inside the !legends block solves this kind of issues. This removes the default maxHeight for icons so that they can extend up to real generated image height.
Mauro
2014-06-12 20:49 GMT+02:00 Bettina Lechner <blechner@anonymised.com>:
Hello,
Thank you!
Bettina
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Mauro,
Thank you for your reply again. Unfortunately, this does not work in my case. I still get the tiny legend entry even with maxIconHeight: 0.
Bettina
blechner@…6560…
Hi Bettina,
Mauro
2014-06-12 20:49 GMT+02:00 Bettina Lechner <blechner@…6560…>:
Hello,
Thank you!
Bettina
blechner@…6560…
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Bettina,
Just worth checking, have you confirmed that your GetLegendGraphics is returning with a full sized legend? It almost certainly is, but worth checking.
My legend is attached below and scales up to fairly large legends:
#Legend
  • !columns
    #This line determines if the legend is shown in the template.
    condition: legends
    absoluteX: 37
    absoluteY: 814
    width: 160
    config:
    borderWidth: 1
    cells:
  • borderWidth: 1
    borderColor: #555555
    padding: 5
    items:
  • !legends
    iconMaxWidth: 145
    iconMaxHeight: 200
    defaultScale: 0.5
    maxWidth: 150
    #Padding between layers
    layerSpace: 5
    layerFont: Helvetica
    layerFontSize: 8
    #Padding between text and icon within layer
    classSpace: 2
    classIndentation: 5
    classFont: Helvetica
    classFontSize: 8
    backgroundColor: white
    inline:true
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 13 June 2014 15:21, Bettina Lechner <blechner@anonymised.com> wrote:
Mauro,
Bettina
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Sent: Friday, June 13, 2014 02:53
To: Bettina Lechner
Subject: Re: [Geoserver-users] Chloropleth legend printing
Hi Bettina,
Mauro
Hello,
Thank you!
Bettina
@mauro_bart
Jonathan,
Thanks for your reply! I noticed in your config, it’s “iconMaxHeight” instead of “maxIconHeight” and changed it to that in mine and that fixed it. Thanks!
Bettina
(402) 554-2088
Hi Bettina,
#Legend
  • !columns
    condition: legends
    absoluteX: 37
    absoluteY: 814
    width: 160
    config:
    borderWidth: 1
    cells:
  • borderWidth: 1
    padding: 5
    items:
  • !legends
    iconMaxWidth: 145
    iconMaxHeight: 200
    defaultScale: 0.5
    maxWidth: 150
    layerSpace: 5
    layerFontSize: 8
    classSpace: 2
    classIndentation: 5
    classFontSize: 8
    inline:true
Jonathan
On 13 June 2014 15:21, Bettina Lechner <blechner@…6560…> wrote:
Mauro,
Bettina
blechner@…6560…
From: maurobartolomeoli@…84… [mailto:maurobartolomeoli@…84…] On Behalf Of Mauro Bartolomeoli
To: Bettina Lechner
Hi Bettina,
Mauro
Hello,
Thank you!
Bettina
blechner@…6560…
@mauro_bart
Hi Bettina,
Wish they could all be that easy! :wink: Glad I could help.
Jonathan
On 13 June 2014 15:56, Bettina Lechner <blechner@anonymised.com> wrote:
Jonathan,
Bettina
(402) 554-2088
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: Friday, June 13, 2014 09:51
To: Bettina Lechner
Cc: Mauro Bartolomeoli; geoserver-users@lists.sourceforge.net
Hi Bettina,
#Legend
  • !columns
    condition: legends
    absoluteX: 37
    absoluteY: 814
    width: 160
    config:
    borderWidth: 1
    cells:
  • borderWidth: 1
    padding: 5
    items:
  • !legends
    iconMaxWidth: 145
    iconMaxHeight: 200
    defaultScale: 0.5
    maxWidth: 150
    layerSpace: 5
    layerFontSize: 8
    classSpace: 2
    classIndentation: 5
    classFontSize: 8
    inline:true
Jonathan
Mauro,
Bettina
To: Bettina Lechner
Hi Bettina,
Mauro
Hello,
Thank you!
Bettina
@mauro_bart
Johnathan is right, I was looking at an old yaml for mapfish-print 1.2. That setting has changed name from 1.2 to 2.0.
Thanks Johnathan.
Mauro
2014-06-13 16:56 GMT+02:00 Bettina Lechner <blechner@anonymised.com>:
Jonathan,
Bettina
(402) 554-2088
To: Bettina Lechner
Hi Bettina,
#Legend
  • !columns
    condition: legends
    absoluteX: 37
    absoluteY: 814
    width: 160
    config:
    borderWidth: 1
    cells:
  • borderWidth: 1
    padding: 5
    items:
  • !legends
    iconMaxWidth: 145
    iconMaxHeight: 200
    defaultScale: 0.5
    maxWidth: 150
    layerSpace: 5
    layerFontSize: 8
    classSpace: 2
    classIndentation: 5
    classFontSize: 8
    inline:true
Jonathan
Mauro,
Bettina
To: Bettina Lechner
Hi Bettina,
Mauro
Hello,
Thank you!
Bettina
@mauro_bart
