[Geoserver-users] Clean install of 2.2.2 not working
I’ve downloaded 2.2.2 binary and placed it on my C:
I’ve installed it per the instructions here: http://docs.geoserver.org/2.2.2/user/installation/windows/binary.html
I’ve altered jetty to point at port 8082. as other stuff is on other ports.
Unfortunately it doesn’t seem to work. My console contains:
Welcome to GeoServer!
JAVA_HOME: C:\Program Files (x86)\Java\jdk1.6.0_26\
Please wait while loading GeoServer…
0 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com vi
a org.mortbay.log.Slf4jLog
280 [main] WARN org.mortbay.log - Deprecated configuration used for C:\geoserver
-2.2.2/webapps
312 [main] INFO org.mortbay.log - jetty-6.1.8
0 [main] WARN org.geoserver.logging - Could not find configuration file for
logging
1310 [main] INFO /geoserver - Initializing Spring root WebApplicationContext
1451 [main] WARN org.springframework.beans.factory.config.CustomEditorConfigure
r - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated:
use PropertyEditorRegistrars or PropertyEditor class names instead. Offending k
ey [org.geotools.util.Version; offending editor instance: org.geoserver.platform
.util.VersionPropertyEditor@anonymised.com
1716 [main] ERROR org.vfny.geoserver.global -
  • GEOSERVER_DATA_DIR: D:\Geoserver_data
2106 [main] WARN org.geoserver - No ‘workspaces’ directory found, unable to lo
ad any stores.
3888 [main] WARN org.springframework.beans.factory.support.DisposableBeanAdapte
r - Invocation of destroy method failed on bean with name ‘geoServerLoader’: or
g.springframework.beans.factory.BeanCreationNotAllowedException: Error creating
bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while
the singletons of this factory are in destruction (Do not request a bean from a
BeanFactory in a destroy method implementation!)
3888 [main] ERROR org.springframework.web.context.ContextLoader - Context initi
alization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean wit
h name ‘gwcFacade’ defined in URL [jar:file:/C:/geoserver-2.2.2/webapps/geoserve
r/WEB-INF/lib/gwc-2.2.2.jar!/applicationContext.xml]: Cannot resolve reference t
o bean ‘gwcTLDispatcher’ while setting constructor argument; nested exception is
th name ‘geoServer’ defined in URL [jar:file:/C:/geoserver-2.2.2/webapps/geoserv
er/WEB-INF/lib/main-2.2.2.jar!/applicationContext.xml]: Initialization of bean f
ailed; nested exception is java.lang.RuntimeException: java.lang.NullPointerExce
ption
at org.springframework.beans.factory.support.BeanDefinitionValueResolver
.resolveReference(BeanDefinitionValueResolver.java:328)
.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.ConstructorResolver.resolve
ConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowir
eConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
Factory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getOb
ject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
y.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
an(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finish
BeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:464)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebA
pplicationContext(ContextLoader.java:385)
at org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:284)
at org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitiali
zed(GeoServerContextLoaderListener.java:18)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.
java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
39)
.java:152)
39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
39)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creati
ng bean with name ‘geoServer’ defined in URL [jar:file:/C:/geoserver-2.2.2/webap
ps/geoserver/WEB-INF/lib/main-2.2.2.jar!/applicationContext.xml]: Initialization
of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullP
ointerException
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
an(AbstractBeanFactory.java:284)
.resolveReference(BeanDefinitionValueResolver.java:322)
… 40 more
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(
GeoServerLoader.java:135)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitializa
tion(GeoServerLoaderProxy.java:54)
Factory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanF
actory.java:394)
Factory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
… 48 more
Caused by: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.readConfiguration(GeoServerLoade
r.java:620)
at org.geoserver.config.DefaultGeoServerLoader.loadGeoServer(DefaultGeoS
erverLoader.java:68)
GeoServerLoader.java:129)
… 52 more
5213 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.
webapp.WebAppContext@anonymised.com{/geoserver,file:/C:/geoserver-2.2.2/webapps/geoserv
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
5244 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.
BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL
[jar:file:/C:/geoserver-2.2.2/webapps/geoserver/WEB-INF/lib/gwc-2.2.2.jar!/appli
cationContext.xml]: Cannot resolve reference to bean ‘gwcTLDispatcher’ while set
ting constructor argument; nested exception is org.springframework.beans.factory
.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL
[jar:file:/C:/geoserver-2.2.2/webapps/geoserver/WEB-INF/lib/main-2.2.2.jar!/app
licationContext.xml]: Initialization of bean failed; nested exception is java.la
ng.RuntimeException: java.lang.NullPointerException:
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
5291 [main] INFO org.mortbay.log - Opened C:\geoserver-2.2.2\logs\2012 _12_13.req
uest.log
5307 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8082
Jetty does work but: http://localhost:8082/geoserver/ - returns me a 503:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/geoserver/
Powered by jetty://
Anyone have any idea as to what’s wrong?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Jonathan,
seams that Geoserver is not able to locate the datadir.Try setting the GEOSERVER_HOME variable as specified into the documentation (reported below):
Note
You may also want to set the GEOSERVER_HOME variable, which is the directory where GeoServer is installed, and the GEOSERVER_DATA_DIR variable, which is the location of the GeoServer data directory (usually %GEOSERVER_HOME\data_dir). The latter is mandatory if you wish to use a data directory other than the one built in to GeoServer. The procedure for setting these variables is identical to the above.
Carlo
Date: Thu, 13 Dec 2012 14:59:47 +0000
Subject: [Geoserver-users] Clean install of 2.2.2 not working
-2.2.2/webapps
logging
.util.VersionPropertyEditor@anonymised.com53…
ad any stores.
alization failed
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
uest.log
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Powered by jetty://
Jonathan
------------------------------------------------------------------------------ LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial Remotely access PCs and mobile devices and provide instant support Improve your efficiency, and focus on delivering more value-add services Discover what IT Professionals Know. Rescue delivers http://p.sf.net/sfu/logmein_12329d2d
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Hi Carlo,
I already have them set.
GEOSERVER_DATA_DIR = D:\Geoserver_data
GEOSERVER_HOME = C:\geoserver-2.2.2\
Note: If I put a trailing \ at the end of GEOSERVER_DATA_DIR, I get a critical bug: http://jira.codehaus.org/browse/GEOS-5500 - Marked down as minor there because it can be worked around by not using a \ at the end.
GeoServer can definitely get to GEOSERVER_DATA_DIR - its placed several directories and files there.
Jonathan
On 13 December 2012 15:36, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
Jonathan,
Note
Carlo
-2.2.2/webapps
logging
ad any stores.
alization failed
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
uest.log
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Powered by jetty://
Jonathan
___________ _________________________ ___________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geoserver-users
Jonathan,
I’m saying that because the problem seams to be this:
ad any stores.
GeoServerLoader is unable to load the workspaces folder:
r.java:620)
Carlo Cancellieri - GeoServer SAS
Date: Thu, 13 Dec 2012 15:59:58 +0000
Subject: Re: [Geoserver-users] Clean install of 2.2.2 not working
To: ccancellieri@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Hi Carlo,
Jonathan
Jonathan,
Note
Carlo
-2.2.2/webapps
logging
ad any stores.
alization failed
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
uest.log
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Powered by jetty://
Jonathan
___________ _________________________ ___________ Geoserver-users mailing list Geoserver-users@anonymised.comsts.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geoserver-users
Hi Jonathan,
Which files did you put on D:\Geoserver_data before its first run?
Did you use your own data directory content or did you moved the default geoserver one, there?
Please, let me know.
Daniele
On Thu, Dec 13, 2012 at 3:59 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
-2.2.2/webapps
logging
ad any stores.
alization failed
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
uest.log
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Powered by jetty://
Jonathan
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
I believe if you point the data directory to an empty directory the behaviour reported (some files are written but error messages) is what happens...
Matthijs
On 2012-12-13 18:02, Daniele Romagnoli wrote:
Hi Jonathan,
Daniele
On Thu, Dec 13, 2012 at 3:59 PM, Jonathan Moules <jonathanmoules@anonymised.com <mailto:jonathanmoules@anonymised.com>> wrote:
    I've downloaded 2.2.2 binary and placed it on my C:\
    I've installed it per the instructions here:
    I've altered jetty to point at port 8082. as other stuff is on
    other ports.
    Unfortunately it doesn't seem to work. My console contains:
    Please wait while loading GeoServer...
    for C:\geoserver
    -2.2.2/webapps
     logging
    1451 [main] WARN
    is deprecated:
    - GEOSERVER_DATA_DIR: D:\Geoserver_data
    2106 [main] WARN org.geoserver - No 'workspaces' directory
    found, unable to lo
    ad any stores.
    3888 [main] WARN
    'geoServerLoader': or
    Error creating
    bean with name 'GWCLifeCycleHandler': Singleton bean creation not
    allowed while
    a bean from a
    Context initi
    alization failed
    creating bean wit
    h name 'gwcFacade' defined in URL
    resolve reference t
    o bean 'gwcTLDispatcher' while setting constructor argument;
    nested exception is
    creating bean wi
    th name 'geoServer' defined in URL
    ption
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
    java:540)
            at
            at
    a:1220)
            at
    510)
            at
            at
    39)
            at
    .java:152)
            at
            at
    39)
            at
    .java:152)
            at
    39)
            at
    130)
            at
    39)
            at
            at
    java:39)
            at
    sorImpl.java:25)
    Caused by:
    ng bean with name 'geoServer' defined in URL
    Initialization
    java.lang.NullP
    ointerException
            at
            at
            at
            at
            at
            at
            at
            at
            at
            ... 40 more
            at
            at
            at
    actory.java:394)
            at
            at
            ... 48 more
            at
    r.java:620)
            at
            at
            ... 52 more
    org.mortbay.jetty.
    er/}
    creating bean wit
    resolve reference t
    nested exception is
    creating bean wi
    ption
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
    java:540)
            at
            at
    a:1220)
            at
    510)
            at
            at
    39)
            at
    .java:152)
            at
            at
    39)
            at
    .java:152)
            at
    39)
            at
    130)
            at
    39)
            at
            at
    java:39)
            at
    sorImpl.java:25)
    Caused by:
    Initialization
    java.lang.NullP
    ointerException
            at
            at
            at
            at
            at
            at
            at
            at
            at
            ... 40 more
            at
            at
            at
    actory.java:394)
            at
            at
            ... 48 more
            at
    r.java:620)
            at
            at
            ... 52 more
    BeanCreationException: Error creating bean with name 'gwcFacade'
    defined in URL
    .BeanCreationException: Error creating bean with name 'geoServer'
    defined in URL
    exception is java.la <http://java.la>
            at
    r.java:620)
            at
            at
            at
            at
    actory.java:394)
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
    java:540)
            at
            at
    a:1220)
            at
    510)
            at
            at
    39)
            at
    .java:152)
            at
            at
    39)
            at
    .java:152)
            at
    39)
            at
    130)
            at
    39)
            at
            at
    java:39)
            at
    sorImpl.java:25)
    uest.log
    <http://SelectChannelConnector@anonymised.com:8082>
    a 503:
    HTTP ERROR: 503
    SERVICE_UNAVAILABLE
    Powered by jetty://
    Anyone have any idea as to what's wrong?
    Jonathan
    services
    <mailto:Geoserver-users@lists.sourceforge.net>
Hi Daniele
None. I used a completely empty directory. I figured GeoServer would populate it as the documentation didn’t tell me otherwise (and it did create a couple of directories).
Jonathan
On 13 December 2012 17:02, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Jonathan,
Daniele
On Thu, Dec 13, 2012 at 3:59 PM, Jonathan Moules <jonathanmoules@anonymised.com942…> wrote:
-2.2.2/webapps
logging
ad any stores.
alization failed
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
uest.log
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Powered by jetty://
Jonathan
Geoserver-users@anonymised.comrceforge.net
On Thu, Dec 13, 2012 at 6:12 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Daniele
Hi Jonathan,
with an empty data dir it won’t work since it needs some specific files and a specific directories structure. Please, take a look at this section of the doc.
http://docs.geoserver.org/2.2.2/user/datadirectory/index.html
Hope this helps.
Daniele
Jonathan
On 13 December 2012 17:02, Daniele Romagnoli <daniele.romagnoli@anonymised.com7…> wrote:
Hi Jonathan,
Daniele
-2.2.2/webapps
logging
ad any stores.
alization failed
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
er/}
ption
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
ointerException
… 40 more
actory.java:394)
… 48 more
r.java:620)
… 52 more
r.java:620)
actory.java:394)
java:540)
a:1220)
510)
39)
.java:152)
39)
.java:152)
39)
130)
39)
java:39)
sorImpl.java:25)
uest.log
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Powered by jetty://
Jonathan
