[Geoserver-users] Clear tile cache overnight for specific WMTS layers?
Hi
I have several layers on a web application where the raw data is updated overnight via scripts. I have noticed that when accessing the layers by WMTS, the cache still shows the data as it was the day before.
Is there an option in Geoserver where I can tell it to remove the client / server cache at a particular time, so that when my scripts run to update my data, I can show it is up to date?
Thanks, Chris
Hi Chris,
I don’t think there is a built-in way to expire tiles at a particular time of day/night,
but once your scripts are done updating the data, you could make them
call truncate or reseed on the GWC REST API:
http://geowebcache.org/docs/1.8.1/rest/seed.html
Hope this helps
On Mon, Apr 4, 2016 at 1:31 PM, Chris Buckmaster <chris.buckmaster@anonymised.com> wrote:
Hi
Thanks, Chris
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks Andrea
I also see there are options for each layer for ‘Expire server cache after n seconds’ and ‘Expire client cache after n seconds’ – presumably the default value of 0 does nothing, but if I set it to 1 then the cache would only be available for 1 second, so the user will always be redrawing with a new cache which might be an option for me?
Hi Chris,
Hope this helps
On Mon, Apr 4, 2016 at 1:31 PM, Chris Buckmaster <chris.buckmaster@…7473…> wrote:
Hi
Thanks, Chris
Ing. Andrea Aime
@geowolf
Technical Lead
Err well yes, but at that point you’ll have a WMTS service that does no caching
and that’s sensibly slower than a WMS service due to metatiling, disk storage and the like…
On Mon, Apr 4, 2016 at 2:13 PM, Chris Buckmaster <chris.buckmaster@anonymised.com> wrote:
Thanks Andrea
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 04 April 2016 13:00
To: Chris Buckmaster
Subject: Re: [Geoserver-users] Clear tile cache overnight for specific WMTS layers?
Hi Chris,
Hope this helps
Hi
Thanks, Chris
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
Yes that does make sense!
Would you recommend for datasets that are updated every day, perhaps it is better to serve over WMS to ensure the correct data is always displayed, or just set a value for example 3,600 to the expire options so that the cache is updated every 2 hours, but layers can be drawn up quicker?
Thanks
On Mon, Apr 4, 2016 at 2:13 PM, Chris Buckmaster <chris.buckmaster@…7473…> wrote:
Thanks Andrea
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Hi Chris,
Hope this helps
Hi
Thanks, Chris
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Dear Chris,
I would recommend truncating and reseeding (partially) over night.
The value is per tile if my memory serves is related to when the tile
is created and unless you seed a layer in advance (completely) you
have no idea when it will be truncated and this might confuse users.
You might find some higher level scripts to get you started with these
tasks here (warning GeoSolutions Blog):
http://www.geo-solutions.it/blog/geowebcache-rest-mangement/
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Apr 4, 2016 at 3:44 PM, Chris Buckmaster
Hi Andrea
Thanks
Andrea Aime
Sent: 04 April 2016 13:22
layers?
Err well yes, but at that point you'll have a WMTS service that does no
caching
and that's sensibly slower than a WMS service due to metatiling, disk
storage and the like...
Thanks Andrea
Andrea Aime
layers?
Hi Chris,
I don't think there is a built-in way to expire tiles at a particular time
of day/night,
Hope this helps
Hi
Thanks, Chris
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Ing. Andrea Aime
@geowolf
Technical Lead
