Does anyone know how to commit and close the connection to the postgres db
after I post to it?
View this message in context: http://www.nabble.com/close-connection-tp14807022p14807022.html
Hi Dominique,
Do you mean after posting a wfs transaction request? If so then the
database connection should be committed after the request, if it is
successul of course. If an error occurs any changes are rolled back.
With GS 1.6.x database connections are pooled, which means connections
are not really closed but thrown back into the pool.
Can you tell us a bit more about how your making the request and why you
need to ensure the connection is closed afterwards?
-Justin
after I post to it?
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
I asked someone about deadlocks and he said “Deadlock on the DB happens when a process performs and update and doe not commit. Make sure your statements are committing and closing the connections.” so I was just wondering if the fact that i’m not committing and closing the connection is the issue.
On 1/14/08, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Dominique,
successul of course. If an error occurs any changes are rolled back.With GS 1.6.x database connections are pooled, which means connections
are not really closed but thrown back into the pool.Can you tell us a bit more about how your making the request and why you
need to ensure the connection is closed afterwards?-Justin
after I post to it?–
Justin Deoliveira
I see. This relates to your deadlock issue with weblogic. Here is an
idea. Would it possible to export some of your data from postgres into a
shapefile. Then set up geoserver to serve the data from the shapefile
and see if the problem persists.
Dominique Bessette - Halsema wrote:
I asked someone about deadlocks and he said "Deadlock on the DB happens
statements are committing and closing the connections." so I was just
wondering if the fact that i'm not committing and closing the connection
is the issue.On 1/14/08, *Justin Deoliveira* <jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>> wrote:Hi Dominique,
you
postgres db
> after I post to it?--
Justin Deoliveira
http://topp.openplans.org!DSPAM:4007,478ba126117901439371379!
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace!DSPAM:4007,478ba126117901439371379!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,478ba126117901439371379!
Justin Deoliveira
I dont really understand what you’re asking me to do, because I have to insert tracks into the database.
is the issue.On 1/14/08, Justin Deoliveira <jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com >> wrote:Hi Dominique,
you
postgres db
Justin Deoliveira
It’s the best place to buy or sell services for
Justin Deoliveira
How are you doing these inserts. Are you going through the wfs
interface... or are you going straight into the back end via some other
script?
I dont really understand what you're asking me to do, because I have to
insert tracks into the database.On 1/14/08, *Justin Deoliveira* <jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>> wrote:I see. This relates to your deadlock issue with weblogic. Here is an
into a
happens
connection
> is the issue.
wrote:
> Hi Dominique,
then the
it is
back.
connections
and why
> you
> -Justin
> postgres db
> > after I post to it?
> Justin Deoliveira
> Geoserver-users@lists.sourceforge.net
<mailto:Geoserver-users@lists.sourceforge.net>
> !DSPAM:4007,478ba126117901439371379!--
Justin Deoliveira
http://topp.openplans.org!DSPAM:4007,478ba3d2125012090977483!
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace!DSPAM:4007,478ba3d2125012090977483!
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,478ba3d2125012090977483!
Justin Deoliveira
i’m posting to the wfs from aqualogic’s esb. so not through an interface.
interface… or are you going straight into the back end via some other
insert tracks into the database.On 1/14/08, Justin Deoliveira < jdeolive@anonymised.com
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:I see. This relates to your deadlock issue with weblogic. Here is an
into a
happens
connection
<mailto:jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>
wrote:Hi Dominique,
then the
it is
connections
and why
you
postgres db
Justin Deoliveira
just about anything Open Source.http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
Justin Deoliveira
Justin Deoliveira
OK... so I assume this means that the ESB is the one who is managing the
connections to the database? I wonder... could the problem be that
GeoServer is using its own connection pool when it should be using one
provided by the app server?
Andrea is our database connection pooling wizard. he may know off hand.
I would to do a bit of searching to find out more info.
i'm posting to the wfs from aqualogic's esb. so not through an interface.
<mailto:jdeolive@anonymised.com>> wrote:How are you doing these inserts. Are you going through the wfs
have to
> On 1/14/08, *Justin Deoliveira* < jdeolive@anonymised.com
is an
> into a
shapefile
> happens
sure your
I was just
> connection
> > is the issue.
<mailto:jdeolive@anonymised.com> <mailto:jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>>>>
> wrote:
> > Hi Dominique,
> then the
request, if
> it is
rolled
> back.
> connections
> and why
> > you
> > -Justin
connection to the
> > postgres db
> > > after I post to it?
> > Justin Deoliveira
<http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace>
> > _______________________________________________
<mailto:Geoserver-users@lists.sourceforge.net>>
<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
> Justin Deoliveira
-------------------------------------------------------------------------> Check out the new SourceForge.net Marketplace.
> !DSPAM:4007,478ba3d2125012090977483!--
Justin Deoliveira
http://topp.openplans.org!DSPAM:4007,478ba94c133791637810514!
Justin Deoliveira
sooooo, i was researching Aqualogic and
"The POST method passes all its data, of unlimited length, directly over the socket connection as part of its HTTP request body. The exchange is invisible to the client, and the URL doesn’t change at all. "
so when i post from geoserver to postgres, aqualogic uses it’s own socket connection, and i’m assuming geoserver does too. so I dont really know what to do, can i turn geoserver’s off? i dont even know if that makes sense.
OK… so I assume this means that the ESB is the one who is managing the
connections to the database? I wonder… could the problem be that
provided by the app server?Andrea is our database connection pooling wizard. he may know off hand.
I would to do a bit of searching to find out more info.Dominique Bessette - Halsema wrote:
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:How are you doing these inserts. Are you going through the wfs
have to
is an
into a
shapefile
happens
sure your
I was just
connection
<mailto: jdeolive@anonymised.com>
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com) <mailto:jdeolive@anonymised.com
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>>
wrote:Hi Dominique,
then the
request, if
it is
rolled
connections
and why
you
connection to the
postgres db
Justin Deoliveira
< http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace>
<mailto:Geoserver-users@lists.sourceforge.net >
<mailto:Geoserver-users@lists.sourceforge.net >>
< https://lists.sourceforge.net/lists/listinfo/geoserver-users>!DSPAM:4007,478ba126117901439371379!
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
