[Geoserver-users] close wfs transaction for out of memory error
Hi everyone,
In my project I HTTP POST geoserver’s wfs with the following code snippet ( i cut out some things)
wfs:Transaction service=“WFS” … >wfs:Insert<cite:tracks >cite:guid…</ cite:guid>cite:the_geom<gml:Point srsName=“urn:EPSG:geographicCRS:4979”><gml:coordinates decimal=“.” cs=“,” ts=" ">…,…,…</gml:coordinates ></gml:Point></cite:the_geom ></cite:tracks></wfs:Insert></ wfs:Transaction>
and now my server is getting an out of memory error, i know that this means there is not enough memory to hold all the objects created. How do i close the transaction in the xml when i am finished with it?
java.lang.OutOfMemoryError: allocLargeArray - Object size: 1048592, Num elements: 1048576
at java.io.BufferedOutputStream.(BufferedOutputStream.java:59)
at org.vfny.geoserver.servlets.FileStrategy.flush(FileStrategy.java:96)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:594)
at org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.java:447)
at org.geoserver.request.Dispatcher.post(Dispatcher.java:301)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:181)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:66)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:358)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:223)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:283)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:42)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3231)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:121)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2003)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:1909)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1359)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:209)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:181)
Hi Dominique,
It is a very large insert?
I notice your GeoServer is configured to use "FileStrategy". While it is
the safest strategy, it is not great for performance as shown below with
the huge array allocation. YOu might confider changing it to
"PartialBufferStrategy". This can be done in the web.xml file. Are you
running jetty out of the box or in another web container.
-Justin
Dominique Bessette - Halsema wrote:
Hi everyone,
In my project I HTTP POST geoserver's wfs with the following code
wfs:Transaction service="WFS" ... ><wfs:Insert><cite:tracks
<cite:guid>...</ cite:guid><cite:the_geom><gml:Point
srsName="urn:EPSG:geographicCRS:4979"><gml:coordinates decimal="."
cs="," ts=" ">...,...,..</gml:coordinates ></gml:Point></cite:the_geom
*java.lang.OutOfMemoryError: allocLargeArray - Object size: 1048592, Num
elements: 1048576 *
        at java.io.BufferedOutputStream.<init>(BufferedOutputStream.java:59)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
!DSPAM:4007,477d337d37012090977483!
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
ok.. .so you if you find the web.xml for geoserver and change the
"serviceStrategy" context parameter to "PARIAL_BUFFER" it could very
well do the trick.
-Justin
I'm not running it on Jetty. My Geoserver is deployed as a web app on
the BEA Weblogic server.
On 1/3/08, *Justin Deoliveira* <jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>> wrote:
    Hi Dominique,
    it is
    -Justin
    > Hi everyone,
    > In my project I HTTP POST geoserver's wfs with the following code
    > snippet ( i cut out some things)
    > wfs:Transaction service="WFS" ... ><wfs:Insert><cite:tracks
    >><cite:guid>...</ cite:guid><cite:the_geom><gml:Point
    > srsName="urn:EPSG:geographicCRS:4979"><gml:coordinates decimal="."
    > cs="," ts=" ">...,...,..</gml:coordinates ></gml:Point></cite:the_geom
    >></cite:tracks></wfs:Insert></ wfs:Transaction>
    > and now my server is getting an out of memory error, i know that this
    > means there is not enough memory to hold all the objects
    created. How
    > do i close the transaction in the xml when i am finished with it?
    > *java.lang.OutOfMemoryError: allocLargeArray - Object size:
    1048592, Num
    > elements: 1048576 *
    > at java.io.BufferedOutputStream
    > at
    > org.vfny.geoserver.servlets.FileStrategy.flush(FileStrategy.java:96)
    > at
    > org.vfny.geoserver.servlets.AbstractService.doService
    > at
    > at org.geoserver.request.Dispatcher.post(Dispatcher.java:301)
    > at
    > at
    > at
    > at
    > at
    > at
    > org.springframework.web.servlet.DispatcherServlet.doService
    > at
    > at
    > org.springframework.web.servlet.FrameworkServlet.doPost
    > at
    > at
    > at
    > at
    :125)
    > at
    > at
    > at
    > at
    :103)
    > at
    > at
    > at
    > at
    > weblogic.security.service.SecurityManager.runAs
    > at
    > at
    > weblogic.servlet.internal.WebAppServletContext.execute
    > at
    > at weblogic.work.ExecuteThread.execute(ExecuteThread.java
    :209)
    > at weblogic.work.ExecuteThread.run(ExecuteThread.java:181)
    > This SF.net email is sponsored by: Microsoft
    > Defy all challenges. Microsoft(R) Visual Studio 2005.
    > http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
    > !DSPAM:4007,477d337d37012090977483!
    > Geoserver-users mailing list
    > Geoserver-users@lists.sourceforge.net
    <mailto:Geoserver-users@lists.sourceforge.net>
    > https://lists.sourceforge.net/lists/listinfo/geoserver-users
    Justin Deoliveira
!DSPAM:4007,477d3f7b59893668746562!
Justin Deoliveira
