[Geoserver-users] Clustered GeoServer on tomcat with load balance on IIS
Hello List,
I tried to make such GeoServer High Availability Set as in this link: http://goo.gl/Hd6F5
Everything works ok except tiled layers .
I tried with default sample layer topp:tasmania_cities.
On separate instances this tiled layer is displayed with no problems.
http://192.168.1.17:8080/geoserver/gwc/demo/topp:tasmania_cities?gridSet=EPSG:4326&format=image/png
http://192.168.1.17:8081/geoserver/gwc/demo/topp:tasmania_cities?gridSet=EPSG:4326&format=image/png
But if I try to view this layer through load balanced on IIS
http://192.168.1.17/geoserver/gwc/demo/topp:tasmania_cities?gridSet=EPSG:4326&format=image/png
I get
Server Error in ‘/’ Application.
A potentially dangerous Request.Path value was detected from the client (:).
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: A potentially dangerous Request.Path value was detected from the client (:).
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): A potentially dangerous Request.Path value was detected from the client (:).]
System.Web.HttpRequest.ValidateInputIfRequiredByConfig() +710
System.Web.PipelineStepManager.ValidateHelper(HttpContext context) +184
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
If I try a group layer (request does not contains „:“) everything work fine too.
I tried to put the following config to web.config of jakarta virtual directory, but no success.
<system.web>
</system.web>
Maybe I missed something?
Thank you for any help.
Sincerely,
Paulius Litvinas
GIS Projects Consultant, “InfoEra” JSC
Mobile: +370 656 10089
Phone: (+370 5) 278 84 56
Fax: (+370 5) 278 47 23
paulius@anonymised.com
S. Zukausko str. 17, LT-08234,
Vilnius, Lithuania
cid:image001.jpg@anonymised.com
www.infoera.com
Ciao Paulius,
I honestly never saw that error myself.
I guess you’ll have to fiddle with the IIS configuration and its security settings.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Aug 29, 2013 at 9:32 AM, Paulius Litvinas <paulius@anonymised.com> wrote:
Hello List,
I get
Source Error:
Stack Trace:
<system.web>
</system.web>
Sincerely,
Paulius Litvinas
Vilnius, Lithuania
www.infoera.com
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk
Geoserver-users mailing list
I found the problem – it was due to .NET version for DefaulAplication pool as virtual directory inherits it from Aplication. I changed it to 2.0 and this solved the problem.
Paul
From: Simone Giannecchini [mailto:simone.giannecchini@anonymised.com]
Sent: Thursday, August 29, 2013 1:07 PM
To: Paulius Litvinas
Cc: geoserver-users
Subject: Re: [Geoserver-users] Clustered GeoServer on tomcat with load balance on IIS
Ciao Paulius,
Simone Giannecchini
@simogeo
Founder/Director
Hello List,
I get
Source Error:
Stack Trace:
<system.web>
</system.web>
Sincerely,
Paulius Litvinas
Vilnius, Lithuania
www.infoera.com
Ciao Paulius,
thanks for reporting this to the list.
Simone Giannecchini
@simogeo
Founder/Director
On Mon, Sep 2, 2013 at 1:47 PM, Paulius Litvinas <paulius@anonymised.com> wrote:
Paul
Cc: geoserver-users
Ciao Paulius,
Simone Giannecchini
@simogeo
Founder/Director
Hello List,
I get
Source Error:
Stack Trace:
<system.web>
</system.web>
Sincerely,
Paulius Litvinas
Vilnius, Lithuania
www.infoera.com
