On Sun, Aug 9, 2015 at 9:09 PM, sikeoka <steve.ikeoka@anonymised.com> wrote:
Even if all code that is calling the list() function always closes the
returned CloseableIterator, the final CloseableIteratorAdapter instance
that
is created in SecureCatalogImpl.list() does not contain the reference to
close the filteredWrapped CloseableIterator so filteredWrapped is left
unclosed when the garbage collector gets to it. The code change in my
previous messages fixes that so closing the CloseableIterator that is
returned by SecureCatalogImpl.list() will close the filteredWrapped
instance.
Ah... I was focusing on that extra <T> in the row, and did not notice
the real change was switching from constructor to factory method
This does not generate the warning message in most cases because
CloseableIteratorAdapter.hasNext() will call close() on itself before
returning false but calling hasNext() until it returns false is not a
requirement. I was able to find an instance in the WMS 1.3.0
GetCapabilities code where hasNext() may not be called until it returns
false although this is likely to happen anywhere where an exception is
thrown while processing the iterator.
This is a portion of the code from Capabilities_1_3_0_Transformer:
private void handleRootBbox(Iterator<LayerInfo> layers) {
while(layers.hasNext()) {
if(latlonBbox.contains(world)){
break;
I did not see a JIRA ticket about this.
Can someone please do it? Nothing gets done without a ticket to remind
us, because it's almost impossible that we have time to work it right away,
and when we find some time a week or a month later, only what's on Jira
gets considered
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
