[Geoserver-users] code runs fine but layer not appearing
I have zero error messages in the coding syntax, however when i go to layer
preview the layer is not there . am i missing something?
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld/ StyledLayerDescriptor.xsd"
                                xmlns="http://www.opengis.net/sld&quot;
                                xmlns:ogc="http://www.opengis.net/ogc&quot;
                                xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <NamedLayer>
   <Name>Jurisdictions</Name>
      <UserStyle>
   <Title>Jurisdictions</Title>
      <FeatureTypeStyle>
   <Rule>
   <Name>city limits</Name>
   <Title>city limits</Title>
    <ogc:Filter>
      <ogc:PropertyIsEqualTo>
        <ogc:PropertyName>type</ogc:PropertyName>
        <ogc:Literal>city limits</ogc:Literal>
     </ogc:PropertyIsEqualTo>
   </ogc:Filter>
   <PolygonSymbolizer>
    <Fill>
           <CssParameter name="fill">#ffffff</CssParameter>
           <CssParameter name="fill-opacity">0.4</CssParameteR>
     </Fill>
     <Stroke>
           <CssParameter name="stroke">#fffffff</CssParameter>
          <CssParameter name="stroke-width">1.3</CssParameter>
          <CssParameter name="stroke-opacity">0.7</CssParameter>
     </Stroke>
   </PolygonSymbolizer>
  </Rule>
  <Rule>
    <Name>police power</Name>
    <Title>police power</Title>
   <ogc:Filter>
         <ogc:Literal>police power</ogc:Literal>
    </ogc:Filter>
   <PolygonSymbolizer>
</Rule>
<Rule>
    <Name>planning commission</Name>
     <Title>planning commission</Title>
    <ogc:Filter>
           <ogc:Literal>planning commission</ogc:Literal>
    </ogc:Filter>
    <PolygonSymbolizer>
       <Fill>
            <CssParameter name="fill">#bbbbbbb</CssParameter>
            <CssParameter name="fill-opacity">0.2</CssParameter>
      </Filll>
      <Stroke>
            <CssParameter name="stroke">#bbbbbb</CssParameter>
            <CssParameter name="stroke-opacity">0.4</CssParameter>
       </Stroke>
       </Rule>
    </FeatureTypeStyle>
   </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
Without a copy of your data it is hard to debug, the usual things to check are is the case of your propertynames correct? is that literal exactly what is in the attribute? Does it work when you use a default polygon style?
Ian
<StyledLayerDescriptor version=“1.0.0”
xsi:schemaLocation=“http://www.opengis.net/sld/ StyledLayerDescriptor.xsd”
xmlns=“http://www.opengis.net/sld
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xlink=“http://www.w3.org/1999/xlink
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”>
Jurisdictions
Jurisdictions city limits city limits type city limits #ffffff 0.4 #fffffff 1.3 0.7 police power police power type police power planning commission planning commission type planning commission #bbbbbbb 0.2 #bbbbbb 1.3 0.4
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
<http://osgeo-org.1560.x6.nabble.com/file/t382810/CaptureSettingsForGeoserverLayerss.png&gt;
i think some of the problems are in the image above. Notice
Aberdeen:Jurisdictions has an unfilled polygon compared to schools layer.
have no idea how to change it to be filled. any thoughts? i'm really new to
geoserver.
The 0 size is more probably the issue, check the data you are loading is really there.
Ian
On 7 March 2018 at 15:32, GeorgeJones92 <george.jones@anonymised.com> wrote:
<http://osgeo-org.1560.x6.nabble.com/file/t382810/CaptureSettingsForGeoserverLayerss.png>
have no idea how to change it to be filled. any thoughts? i’m really new to
geoserver.
Ian Turton
the data is there. i run it off pg admin database. idk if you know to much
about that but i originally deleted the old jurisdictions layer and added a
new one but can't get that to show up in geoserver. idk how to make a
connection to it.
-george
<http://osgeo-org.1560.x6.nabble.com/file/t382810/failed_to_load_list.png&gt;
also i keep getting the above error message when submitting the layer
attributes with the installed code. absolutely no idea what it means- i'm
missing attributes?
thanks GJ
