[Geoserver-users] Color blending example not valid?
Hi all. As part of the 2.7 release process I got to copyedit the new color-blending docs, but not actually go through the example.
http://docs.geoserver.org/2.7.0/user/styling/sld-extensions/composite-blend/example.html
I'm doing that now, and finding that the SLD as saved doesn't validate:
http://docs.geoserver.org/2.7.0/user/_downloads/statesblend.sld
Specifically, the errors seem to be regarding having FeatureTypeStyle-level VendorOptions.
line 69: cvc-complex-type.2.4.a: Invalid content was found starting with element 'VendorOption'. One of '{"http://www.opengis.net/sld":Rule\}' is expected.
line 81: cvc-complex-type.2.4.a: Invalid content was found starting with element 'VendorOption'. One of '{"http://www.opengis.net/sld":Rule\}' is expected.
Is this user error, SLD error, or a bug?
Mike
Mike Pumphrey
User Advocate | Boundless
mike@anonymised.com
http://boundlessgeo.com
@boundlessgeo
element 'VendorOption'. One of '{"http://www.opengis.net/sld&quot;:Rule\}' is
expected.
expected.
Sigh, every time we forget to add new elements to the SLD this comes up...
the file is valid,
but I evidently forgot to update the SLD schemas used to perform validation.
And yet... just checked the schema, the VendorOption is there:
<xsd:element name="FeatureTypeStyle">
  <xsd:annotation>
    <xsd:documentation>
      A FeatureTypeStyle contains styling information specific to one
      feature type. This is the SLD level that separates the 'layer'
      handling from the 'feature' handling.
    </xsd:documentation>
    </xsd:annotation>
    <xsd:complexType>
      <xsd:sequence>
        <xsd:element ref="sld:Name" minOccurs="0"/>
        <xsd:element ref="sld:Title" minOccurs="0"/>
        <xsd:element ref="sld:Abstract" minOccurs="0"/>
        <xsd:element ref="sld:FeatureTypeName" minOccurs="0"/>
        <xsd:element ref="sld:SemanticTypeIdentifier" minOccurs="0"
                    maxOccurs="unbounded"/>
        <xsd:element ref="sld:Transformation" minOccurs="0"/>
        <xsd:element ref="sld:Rule" maxOccurs="unbounded"/>
        <xsd:element ref="sld:VendorOption" minOccurs="0"
maxOccurs="unbounded" />
      </xsd:sequence>
    </xsd:complexType>
  </xsd:element>
Not sure what's going on here, did we start using some other schema for
validation,
other than the ones in gt-xsd-sld??
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for confirming. Drat, wishing I had just tested validation of the existing SLD when I was copyediting.
Not being sure whether this is a GeoTools or GeoServer issue, where should I ticket this?
Mike
Mike Pumphrey
mike@anonymised.com
@boundlessgeo
expected.
expected.
the file is valid,
   <xsd:annotation>
     <xsd:documentation>
     </xsd:annotation>
     <xsd:complexType>
       <xsd:sequence>
       </xsd:sequence>
     </xsd:complexType>
   </xsd:element>
validation,
Decided to ticket this issue in GeoServer land. Please move as appropriate:
https://osgeo-org.atlassian.net/browse/GEOS-6971
Mike
Mike Pumphrey
mike@anonymised.com
@boundlessgeo
Mike
Mike Pumphrey
mike@anonymised.com
@boundlessgeo
expected.
expected.
the file is valid,
   <xsd:annotation>
     <xsd:documentation>
     </xsd:annotation>
     <xsd:complexType>
       <xsd:sequence>
       </xsd:sequence>
     </xsd:complexType>
   </xsd:element>
validation,
