On Sun, Aug 7, 2016 at 5:13 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Hi Andrea,
Thanks for noting the WFS 2.0 joins (I obviously didn't know about
them:)).
Is the join delegated to the GeoTools DataStore level or does GeoServer
execute queries across the layers?
Hi Jim,
fair question, indeed the join support has some limitations compared to the
filter subsystem:
- It can be only delegated to the store, there is no in memory execution
support
- As a consequence, the tables in the join must all reside in the same
source, and the filters in the join must be fully encodable
- Only "star" joins are supported (single central feature type linking
to N others), this is a limitation of the API, Query has a list of Join
objects, but a Join cannot have child joins, meaning a "list join" (a join
b join c join d) cannot be expressed
- Presently, there is no way to say that you want to join N feature
types, but only return one (so it's not possible to use joins as a pure
filtering mechanism, but only as a tuple building one, the client has to
throw away the excess weight after the fact)
The store needs to declare support for joins in its query capabilities, so
far only the JDBC ones support that.
For more details see:
https://github.com/geotools/geotools/blob/master/modules/library/api/src/main/java/org/geotools/data/Query.java#L79
https://github.com/geotools/geotools/blob/master/modules/library/api/src/main/java/org/geotools/data/Join.java
https://github.com/geotools/geotools/blob/master/modules/library/api/src/main/java/org/geotools/data/QueryCapabilities.java#L112
Of course, resources/funding to improve the join subsystem would be quite
welcomed!
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
