[Geoserver-users] Combining map services to one map serivce
Dear all,
I am looking to find a solution to combine different map services into one service.
Example: Every municipality collects building data on a local level. The municipalities are working with different systems and every municipality runs a service with their building data.
We would like to share the data on a national level and we want to combine all these services into one service.
This is still on a concept level but we have to brainstorm on the fact, that the municipalities do not trust each other and they are not willing to share their data into one database.
What are the limits of combining a lot of different services?
Kind regards,
Alexander
On Sun, Nov 30, 2014 at 10:23 AM, Strunck, Alexander GIZ PS <
alexander.strunck@anonymised.com> wrote:
Dear all,
service.
Some time ago we built something similar for WFS, same situation:
http://www.geo-solutions.it/blog/geoserver-aggregating-datastore-aggregate-and-republish-from-several-data-sources/
In your case it's WMS, so it would require a different solution. I'd say
the buildilng blocks are almost there already,
the aggregating data store could be replaced by the mosaick one, and the
wfs one by the ability to cascade
by the WMS cascading support, we just have no way to mix them toghether,
someone would need to write
a property WMS coverage store (what we have now it's not fully implement,
just enough to allow GeoServer
to use it), and then some tooling to build a mosaick out of them.
I guess the reader would have to start off the caps link, but would also
need a list of layers to be cascaded, and
the format to be used for cascading
Given the experience with the WFS aggregating one, the important bits are:
* ability to make all the requests in parallel, to avoid waiting a lot,
especially over the slowest servers of the lot
  (mosaick can do this already)
* ability to only cascade over the servers that are in the area requestest
(mosaick does this already)
* tolerate failures, when hitting many distributed servers having all of
them online and working at the same
  time is more the exception than the rule (this would need to be
developed, right now the mosaicking request
  fails if one of source readers fails)
Not sure if this is your case, but if reprojection is in the mix because
not all source servers are accepting
the output, requested CRS, small diferences in reprojection accuracy on the
source servers might also
be an issue
Hope this helps.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
And oh, I went for the high performance solution without thinking of the obvious one: cascade
them all, and then create a layer group.
However, this solution does not satisfy any of the desirable points in my bullet list, it will
make requests one after the other, fail if one of the remote servers fail, and will make
requests to remote servers even if they are out of their covered bounding box.
On Mon, Dec 1, 2014 at 9:29 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sun, Nov 30, 2014 at 10:23 AM, Strunck, Alexander GIZ PS <alexander.strunck@anonymised.com> wrote:
Dear all,
In your case it’s WMS, so it would require a different solution. I’d say the buildilng blocks are almost there already,
the aggregating data store could be replaced by the mosaick one, and the wfs one by the ability to cascade
by the WMS cascading support, we just have no way to mix them toghether, someone would need to write
a property WMS coverage store (what we have now it’s not fully implement, just enough to allow GeoServer
I guess the reader would have to start off the caps link, but would also need a list of layers to be cascaded, and
  • ability to make all the requests in parallel, to avoid waiting a lot, especially over the slowest servers of the lot
  • ability to only cascade over the servers that are in the area requestest (mosaick does this already)
  • tolerate failures, when hitting many distributed servers having all of them online and working at the same
    time is more the exception than the rule (this would need to be developed, right now the mosaicking request
Not sure if this is your case, but if reprojection is in the mix because not all source servers are accepting
the output, requested CRS, small diferences in reprojection accuracy on the source servers might also
be an issue
Hope this helps.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Dear Andrea,
Thank you for your input.
I am very interested in your solution and the extension.
Since the blog article is from 2011 I could not find the extension. Can you send a short manual how to set up your solution.
I would like to test it.
Kind regards,
Alexander
On Sun, Nov 30, 2014 at 10:23 AM, Strunck, Alexander GIZ PS <alexander.strunck@…6806…> wrote:
Dear all,
be an issue
Hope this helps.
Ing. Andrea Aime
@geowolf
Technical Lead
Ciao Alexander,
the link for the nightly builds has changed over time.
The aggregate datastore plugin can be find at the following link for master:
http://ares.boundlessgeo.com/geoserver/master/community-latest/geoserver-2.7-SNAPSHOT-aggregate-plugin.zip
There are similar links for 2.4.x, 2.5.x, 2.6.x:
Simone Giannecchini
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Dec 3, 2014 at 10:39 AM, Strunck, Alexander GIZ PS
Dear Andrea,
Kind regards,
Alexander
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of
Andrea Aime
Sent: Monday, December 1, 2014 10:29
To: Strunck, Alexander GIZ PS
Subject: Re: [Geoserver-users] Combining map services to one map serivce
Dear all,
service.
In your case it's WMS, so it would require a different solution. I'd say the
be an issue
Hope this helps.
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
Deutsche Gesellschaft fuer Internationale Zusammenarbeit (GIZ) GmbH;
Sitz der Gesellschaft Bonn und Eschborn/Registered offices Bonn and
Eschborn, Germany;
Registergericht/Registered at Amtsgericht Bonn, Germany;
Eintragungs-Nr./Registration no. HRB 18384 und/and Amtsgericht Frankfurt am
Main, Germany; Eintragungs-Nr./Registration no. HRB 12394;
USt-IdNr./VAT ID no. DE 113891176;
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: Dr.
Friedrich Kitschelt, Staatssekretaer/State Secretary;
Vorstand/Management Board: Tanja Goenner (Vorstandssprecherin/Chair of the
Management Board), Dr. Christoph Beier (Stellv. Vorstandssprecher/Vice-Chair
of the Management Board), Dr. Hans-Joachim Preuss, Cornelia Richter
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
