[Geoserver-users] community modules
Some time ago, you could find community modules for donwload at http://ares.boundlessgeo.com/geoserver/master/community-latest
This link does not seem to work anymore.
Is there another resource where we could get the community modules, or do we have to build them as needed, by ourselves ?
Best,
Jean
Jean Pommier – pi-Geosolutions
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
There is a link off geoserver.org for various builds.
A couple of clicks later you’ll get to https://build.geoserver.org/geoserver/master/community-latest
ares is no more.
However the build server is a little loaded at the moment, so you might want to give it a day or two.
Brad
It’s actually fully offline for maintenance, there is no clear ETA for when it’s going to be back at the moment.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Oh, I’m sorry, I missed this link. I never noticed you have slightly different content if you select the Nightly builds link instead of the regular tagged link
Thanks !
Jean
ares is no more.
Brad
Where is that link actually? I can’t find it from the download page. Some of the community module documentation still link to the download page, but it doesn’t seem possible to find the community modules from there, unless I am missing something.
Regards
Niels
ares is no more.
Brad
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Community modules are accessible only via nightly builds, so for example go here:
http://geoserver.org/release/2.14.x/
and scroll to the very bottom of the mage, there’s a link to the community modules listing on the build server (now not working, the build server is still offline)
Note even when that server comes back I doubt historic community modules will be available. You should consider building from source for the best experience (ie to be sure of compatibility with the release of GeoSever you are using).
The community module links are intended to share ideas and RnD for feedback. If you have any community modules you use and enjoy consider talking with the developers about the steps needed to fold the functionality into GeoServer.
Jody Garnett
