(please keep questions on the public mailing list)
An example of a polygon filter in an xml style filter:
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>the_geom</ogc:PropertyName>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>..</gml:coordinates>
<gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ogc:BBOX>
</ogc:Filter>
Yes, you should be able to use a CQL filter in a WFS request. Something like the following:
WITHIN(the_geom,polygon((...)))
Hope that helps.
-Justin
Swärd Mårten wrote:
Hello Justin, and thanks for your answer! You don't happen to have a example of a query with a polygon filter? =)
Can you do a WFS-query with a CQL-statement? Something like "SUM(population) WHERE the_geom WITHIN 'polygon(54 18, 54 17 .. ..)'
Thanks again!
- Mårten************************************************************************
Mvh:
Mårten Swärd
Systemutvecklare/Webbutvecklare, ITs
SMHI, Sveriges Meteorologiska och Hydrologiska Institut
Tel: +46 11 495 8469-----Ursprungligt meddelande-----
Från: Justin Deoliveira [mailto:jdeolive@anonymised.com] Skickat: den 18 mars 2008 16:13
Till: Swärd Mårten
Kopia: geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] Compare attributes between different layers?Unfortunately not with a single WFS. You would have to write some sort of script or program to make the first request, then execute a second query with a polygon filter or something like that.
-Justin
Swärd Mårten wrote:
Hello!
Is it possible to make queries and compare attributes between two different layers? For example if I have a layer with population/km2 and a layer with counties (polygon) and then want to check how many people that lives I a specific county.
Is this possible (SLD, CQL)? If yes, does anyone have an example how to do this?
Best reagards: Mårten
Defy all challenges. Microsoft(R) Visual Studio 2008.
http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/!DSPAM:4007,47dfb8dd194581137850744!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,47dfb8dd194581137850744!
