G’day everyone,
I’m after some help from someone who has installed the complex features branch / community schema branch of GeoServer.
I’ve followed the notes on the ComplexDataStore documentation and after grasping the concepts attempted to get all the pieces together. I’m not sure how to download all the pieces as it doesn’t come as a war/exe file as in other releases. If I download the files individually I’m not sure where the files go and whether I need other components to make this branch work.
I’ve also downloaded the community schema 0.3 from sourceforge under the latest GeoServer releases ( http://sourceforge.net/project/showfiles.php?group_id=25086 ). This seems to be a cut down version of the full GeoServer install. I’ve tried adding the missing directories/files from the latest stable release of GeoServer but couldn’t get this to work.
Thanks so much for your help.
Andy
Andy Townsend
BlueNet Project
Australian Antarctic Data Centre
Australian Antarctic Division
Channel Hwy
Kingston TAS 7050
03 6232 3572 (Aust)
+61 3 6232 3572 (Int’l)
www.bluenet.org.au
www.aad.gov.au
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.antarctica.gov.au/
