Hi Paul,
I’m not sure if I understand your question correctly, but have you
already checked into the composite-base option?
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/composite-blend/syntax.html#composite-bases
Btw, composition can only be controlled in SLD at the moment, there
is no way to alter it from the GetMap request URL (although I would not mind
adding a way to specify which layers are composite basis from the request, in
a dynamic way)
On Thu, Jun 9, 2016 at 6:24 PM, hanshupe <paul.schneeweiss@anonymised.com> wrote:
Hello,
I use the destination-in vendor option to use a polygon layer like a mask,
so that only some parts of a raster layer are shown. The sld is defined for
my polygon layer.
In my WMS call a specify both layers:
layers=layer_polygon,layer_raster1&…
Now I want to add other vector and raster layers in my wms url, which should
not be affected by the destination-in parameter.
How can I tell that the composite and blending rule should be valid only for
a specific layer in my url? Any ideas?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Composite-and-blending-for-specific-layer-in-WMS-call-tp5270902.html
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
