[Geoserver-users] Concerning the Windows install for GeoServer
Hi Johan. This question is best suited for the GeoServer-users mailing list, as there are others who are able to respond very much faster (and probably more accurately) than I am.
That said, I have updated the Windows installer page and tried to eliminate the outdated/incorrect information. You are right that the console will persist, and that you may have to manually set the JAVA_HOME variable. This is normal and can be disregarded. When GeoServer is running, you can head to http://localhost:8080/geoserver and you should see the admin interface.
Hope this helps.
Mike
Johan Mares wrote:
I am trying to setup up geoserver (both Centos 5.2 and Windows 2003 server).
The linux installatian works mostly (still some errors), but I had more trouble with the windows installation. And since you are both the author of the manual I send this email to you.
http://geoserver.org/display/GEOSDOC/1.1.1+Windows+Install
I installed JDK 1.6.0_06
The link (http://docs.codehaus.org/display/GEOS/Download) to download the latest Geoserver .exe doesn't work. I used http://geoserver.org/display/GEOS/Stable
I had to set the JAVA_HOME manually.
The image under item 4 (start geoserver) is missing
Unable to render embedded object: File (start_menu_windows.png) not found.
When you start geoserver is the console window supposed to remain open ?
Kind regards,
Johan Mares
IT specialist & developer
Tel. +32-(0)59-34 01 68
VLIZ - InnovOcean site
Vlaams Instituut voor de Zee
Flanders Marine Institute
http://www.vliz.be
!DSPAM:4051,4869f2bb126415409313003!
