[Geoserver-users] conect GeoServer 1.6.5 to SDE 9.1
Hi, I have GeoServer 1.6.5 in linux and I have SDE 9.1. I want to make a
link between they. I downloaded the files for sde 9.1 and pasted the jar
file (gt2-arcsde-2.4.5.jar) in /geoserver/webapps/geoserver/WEB-INF/lib
but the label SDE doesn't appear in Data->Store-> new.
When I runs the geoserver appear the next message two times "WARN
[geotools.arcsde] - ArcSDE Java API seems to not be on your classpath.
Please verify that all needed jars are. ArcSDE data stores will not be
available."
could you help me??
Thanks
Arturo Juárez Lima
Unfortunately, licensing issues prevent us from distributing all of the libraries needed for this particular plugin.
Please see http://docs.codehaus.org/display/GEOTDOC/ArcSDE+DataStore for information on acquiring the needed .jar files for your ArcSDE installation.
Hope this helps,
-David Winslow
available."
could you help me??
Thanks
*//**/ Arturo Juárez Lima/*
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Hi, I maked the link of geoserver with the sde, but when I want to make a new entity, and I select a shape from my conection to my SDE, send me this:
    HTTP ERROR: 500
NONE
RequestURI=/geoserver/config/data/typeNewSubmit.do
      Caused by:
java.lang.NoSuchFieldError: NONE
  at org.geotools.data.arcsde.ArcSDEAdapter.createAttributeTypes(ArcSDEAdapter.java:347)
  at org.geotools.data.arcsde.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:273)
  at org.geotools.data.arcsde.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:228)
  at org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:84)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
  at org.mortbay.jetty.Server.handle(Server.java:303)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
  at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:735)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
/Powered by Jetty:// <http://jetty.mortbay.org/&gt;/
any idea??<Llorar>
Thanks
*//**/Arturo Juárez Lima/*
Hope this helps,
-David Winslow
available."
could you help me??
Thanks
<Excitado>answered by myself, only I dated all jars files for SDE and SDK
Thanks <Tranquilo>
Arturo Juàrez escribió:
Arturo Juárez Lima
HTTP ERROR: 500
NONE
Caused by:
Powered by Jetty://
any idea??<Llorar>
Thanks
Arturo Juárez Lima
Hope this helps,
-David Winslow
but the label SDE doesn’t appear in Data->Store-> new.
When I runs the geoserver appear the next message two times “WARN
available.”
could you help me??
Thanks
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
[http://moblin-contest.org/redirect.php?banner_id=100&url=/](http://moblin-contest.org/redirect.php?banner_id=100&url=/)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
