[Geoserver-users] Config cascading WMS 1.3: Capabilities req params overruled
Dear all,
Configuring a cascading WMS, one has to provide Connection Info, for example the Capabilities URL. Although I provide a full Capbilities URL to a WMS 1.3 service, the actual request sent to remote WMS has the string “REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS” tagged onto the end. This effectively overrules the request supplied.
We’re running GeoServer v.2.4.0. Any thoughts why this happens? Is this by design?
Edward
Please check what you get back from the remote server if you send a GetCapabilities request with &VERSION=1.3.0. I bet it is sending back a document in WMS 1.1.1 format because it does not support WMS 1.3.0. After that Geoserver continues discussion with the WFS 1.1.1 protocol. This is by design and build in into WMS standard. Read more about version negotiation from the WMS 1.3.0 standard, it begins from page 10.
However, if my guess was wrong and the remote server supports WMS 1.3.0 then there is something else going on and we need to get some more information. The server URL would be best but I know that all servers are not public. By the way, there is nothing better in WMS 1.3.0 than in 1.1.1 so if it works so just use it.
-Jukka Rahkonen-
Edward Mac Gillavry wrote:
Dear all,
Edward
On Thu, Sep 4, 2014 at 3:12 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
It may also be that the client fails to deal with the 1.3.0 capabilities
document returned, and falls back to 1.1.1.
I remember issues cascading servers exposing the INSPIRE extra metadata for
example, that was solved at some point, but can't exactly remember when
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for your pointers. The upstream WMS server (SharpMap) ONLY supports WMS 1.3. Sending a proper, full GetCapabilities request version 1.3 to the upstream WMS server using wget or the web browser, I get the proper document in response.
The “client” here is GeoServer, as I am configuring the upstream WMS as a store in the GS management interface with the exact same GetCapabilities URL for version 1.3. Upon adding layers, GS appears to hijack the request tagging version 1.1.1 onto the end of the request.
No INSPIRE metadata is involved in the exchange.
Hope this makes it more clear.
Thanks in advance,
Edward
Date: Thu, 4 Sep 2014 15:25:04 +0200
Subject: Re: [Geoserver-users] Config cascading WMS 1.3: Capabilities req params overruled
To: jukka.rahkonen@anonymised.com
CC: emacgillavry@anonymised.com; geoserver-users@lists.sourceforge.net
On Thu, Sep 4, 2014 at 3:12 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com6…> wrote:
It may also be that the client fails to deal with the 1.3.0 capabilities document returned, and falls back to 1.1.1.
I remember issues cascading servers exposing the INSPIRE extra metadata for example, that was solved at some point, but can’t exactly remember when
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 4, 2014 at 3:47 PM, Edward Mac Gillavry <
emacgillavry@anonymised.com> wrote:
The "client" here is GeoServer, as I am configuring the upstream WMS as a
Eh, no idea then. Try a more recent version of GeoServer, if that does not
work either, please open a bug report
with a link to a accessible WMS server for further tests (if you don't have
one, that's a big problem, because
we won't be able to do anything about it I'm afraid)
Ing. Andrea Aime
@geowolf
Technical Lead
Will upgrade GS version and check whether issue persists.
Edward
Date: Thu, 4 Sep 2014 15:51:28 +0200
To: emacgillavry@anonymised.com
CC: jukka.rahkonen@anonymised.com; geoserver-users@lists.sourceforge.net
On Thu, Sep 4, 2014 at 3:47 PM, Edward Mac Gillavry <emacgillavry@anonymised.com…> wrote:
Eh, no idea then. Try a more recent version of GeoServer, if that does not work either, please open a bug report
with a link to a accessible WMS server for further tests (if you don’t have one, that’s a big problem, because
we won’t be able to do anything about it I’m afraid)
Ing. Andrea Aime
@geowolf
Technical Lead
