[Geoserver-users] Configuration of staged GeoServer installations
our development process for a GeoServer project consists of the typical stages:
- continuous integration stage
- user acceptance test stage
- production stage
The GeoServer configuration is the same for all stages except from a
few properties like
- URLs of cascaded, external WMS
- URLs of cascaded, external WFS
We have the geoserver data dir under version control and deploy the
data dir to each of the stages.
Problem:
The configuration has to be adjusted per stage.
Currently we adjust this configuration by automated search & replace
in our deployment pipeline.
However, at our customers site that is not easily possible.
I think it would be nice to have variable substitution in various
settings, like external URLs. Maybe substitution from system property
or the like. But I suppose variable substitution is not yet available,
is it?
Question:
How do you handle this?
Best regards,
Andreas
On Wed, Feb 24, 2016 at 5:44 PM, Andreas Watermeyer <
is it?
It is not indeed. For database connections you can use JDNI to externalize
the connection pool configuration, but for the rest, no support yet.
(and yes, it is annoying).
I agree it would be great to have some level of variable substitution...
for datastores I believe it may not be too hard, if there are other
settings it might get annoying... as in, it will be a case by case thing.
A guide for these requests:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
variable substitution might be quite easy to achieve when implemented in the config parsing layer - XStream.
XStream has “Converters” for example for to-string conversion. That might work, affecting all configurations globally.
What do you think?
Best regards,
Andreas
2016-02-24 18:02 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
On Wed, Feb 24, 2016 at 5:44 PM, Andreas Watermeyer <Andreas.Watermeyer@anonymised.com> wrote:
is it?
I agree it would be great to have some level of variable substitution…
settings it might get annoying… as in, it will be a case by case thing.
Ing. Andrea Aime
@geowolf
Technical Lead
Andreas Watermeyer
office: +49 (0)221 820 07 14
ITS Telco Services GmbH
GIS Services & Solutions
Telecommunications Division
Dillenburger Str. 77
D-51105 Köln
Tel.: +49 (0)221 820 07 00
Fax : +49 (0)221 820 07 22
Mail: info@anonymised.com
Web : http://www.its-telco.de
Sitz der Gesellschaft: Köln
Amtsgericht Köln, HRB 59310
Geschäftsführer: Gunnar Haack, Ralf Petersilka, Michael Schnepf, Kai Schriewer, Ludger Schulte
Diese E-Mail enthält vertrauliche Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
This e-mail may contain confidential information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
On Thu, Feb 25, 2016 at 2:06 PM, Andreas Watermeyer <
Hi Andrea,
XStream has "Converters" for example for to-string conversion. That might
What do you think?
Could work, but wouldn't it mean that you cannot edit stuff with variables
anymore in the UI, and if you
try to edit and save, you might get your variable overridden (unless of
course there is something replacing them back).
Anyways, it's a possibility, but GeoServer makes heavy use of custom
converters, some of which spread out in the code
base, so... hmm... could be quite a bit of work, and again, case by case
stuff (which field of which bean do we need
to perform substitution on?).
Also, not everything in GeoServer is driven by XStream, some community
modules are not, not completely
sure what the security subsytem does either.
Anyways, here is the largest concentrated lot of converters, but you'll
find others around:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/util/XStreamPersister.java
As said, I'd first identify which types of configuration you want to make
templatable, and then
check what can be done depending on how they are managed internally.
Ing. Andrea Aime
@geowolf
Technical Lead
