Hi all
We are using the sqlserver datastore to connect Geoserver 1.7.2 to sqlserver 2008. We have to sqlserver instances installed on the machine, I try to connect to the default instance.
When trying to configure a new Feature Type, I can not select any spatial tables that exist in sqlserver.
Looking into the log, two things could cause my problems:
- There’s code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
This is probably due to the fact that the datastore is still experimental… - Unable to fetch a list of FeatureType names from datastore. java.lang.RuntimeException: Unable to obtain connection
This could be because the configuration of my sqlserver datastore is wrong. However, I do not get any errors when configuring the datastore.
I wonder whether it is correct to configure gis_db as schema… gis_db is the database containing the spatial tables we want to show with geoserver. (Zylindrical Icon in SqlServer Management Studio)
Help would be greatly appreciated, I am struck…
Oliver
configuration of datastore:
log:
2009-03-02 17:55:33,592 ERROR [geotools.jdbc] - There’s code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
2009-03-03 06:47:19,026 ERROR [geoserver.ows] -
org.mortbay.jetty.EofException
at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:548)
at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:569)
at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:910)
at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:646)
at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:577)
at org.geoserver.filters.AlternativesResponseStream.write(AlternativesResponseStream.java:59)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
at org.vfny.geoserver.servlets.FileStrategy.flush(FileStrategy.java:126)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:713)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
at sun.nio.ch.SocketDispatcher.write0(Native Method)
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:33)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:104)
at sun.nio.ch.IOUtil.write(IOUtil.java:60)
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:334)
at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:207)
at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
… 60 more
2009-03-03 07:09:58,885 ERROR [geotools.jdbc] - There’s code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
2009-03-03 07:10:33,338 WARN [geoserver.action] - Unable to fetch a list of FeatureType names from datastore.
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1142)
at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:628)
at org.geotools.data.store.ContentDataStore.getTypeNames(ContentDataStore.java:263)
at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:80)
at org.vfny.geoserver.util.DataStoreUtils.acquireDataStore(DataStoreUtils.java:59)
at org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:145)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Login failed for user ‘ftth_admin’.)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1134)
… 59 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user ‘ftth_admin’.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSParser.parse(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$000(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.loginWithoutFailover(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(Unknown Source)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(Unknown Source)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
… 61 more
2009-03-03 07:11:21,932 ERROR [geotools.jdbc] - There’s code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
