Have you tried to give the lat-lon bounding box manually instead of calculating it from data? Does it give the same error?
-Jukka Rahkonen-
Krešimir Križanović wrote:
Hi, i posted a couple of weeks ago about trying to connect geoserver to Informix spatial database.
I decided to try with setting up IBM Informix WFS and connecting geoserver to it. I managed to set up a connection, and get a feature list (I’m guessing that GetCapabilities is working fine). However, when I try to calculate Bounding Boxes from data (setting up a new layer), I get a null pointer exception. Stack trace is at the end of the mail. Maybe I don’t know where to look, but I can’t find anything in the log.
Maybe the following is relevant. I managed to visualize data from the same IBM Informix WFS using Gaia from The Carbon Project. However, I had to uncheck BBOX Filter. It seems there is a problem with calculating bounding boxes around data.
When I look at data and enter Native Bounding Box data manually, I can create a new layer. However, when I try to preview it, I get the following GML:
error:java.lang.RuntimeException: Error reading Features java.lang.RuntimeException: Error reading Features Error reading Features Could not aquire feature:org.geotools.data.DataSourceException: Authority “UNKNOWN” is unknown or doesn’t match the supplied hints. Maybe it is defined in an unreachable JAR file? Authority “UNKNOWN” is unknown or doesn’t match the supplied hints. Maybe it is defined in an unreachable JAR file? Authority “UNKNOWN” is unknown or doesn’t match the supplied hints. Maybe it is defined in an unreachable JAR file?
Can you give me some pointers where to look for the solution to this problem, or let me know what additional data you need.
Kresimir Krizanovic
University of Zagreb, Croatia
Faculty of Electrical Engineering and Computing
Stack trace:
java.lang.NullPointerException
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:661)
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:624)
at org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getFeatureTypeBounds(WFS_1_1_0_DataStore.java:723)
at org.geotools.data.wfs.v1_1_0.CapabilitiesResourceInfo.getBounds(CapabilitiesResourceInfo.java:62)
at org.geotools.data.wfs.v1_1_0.WFSFeatureSource.getBounds(WFSFeatureSource.java:116)
at org.geoserver.feature.retype.RetypingFeatureSource.getBounds(RetypingFeatureSource.java:148)
at org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:591)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:561)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:543)
at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:118)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
