[Geoserver-users] Controlflow
Ciao Vikram,
  1. I added controlflow.jar in C:\Program Files\Apache Software Foundation\Tomcat 7.0_Tomcat7_8080\webapps\geoserver\WEB-INF\lib
  2. After that I added controlflow.properties with certain configuration. But no effect in geoserver.
No visible effect should be noted, to check if it is working try looking at the logs.
You may also limit the total amount of requests to 1 and firing multiple requests in parallel (with OpenLayers and tiled=true) to check if some request will be rejected.
Most of the parameters and limits to configure into the control.flow are VERY dependent by the served data and by the number and type of requests to serve.
So in most cases you have to tune it using the experience and data coming out after a period (as long as possible) of test profiling requests coming out from users (use monitoring plugin for this).
  1. What are all the parameters to be checked in Apache Jmeter. ?
There are meny posts to know how to configure jmeter with geoserver (try to search over the ML).
PS: keep the MailingList into the loop to also get support from other guys.
Carlo
S. Thiruvikraman M.Sc.,
Ph: +919746149212 , +919003419957
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
