Thanks again for your help Torben.
On Mon, Nov 6, 2017 at 12:53 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Kris,
You can view a style for a certain workspace using the following endpoint: /rest/workspaces/{workspaceName}/styles
See the API docs for more info: http://docs.geoserver.org/api/#/1.0.0/styles.yaml
There is no way of viewing all styles at once using the rest API.
Torben
On Mon, Nov 6, 2017 at 9:55 AM, Kris Johnson <kristofj@anonymised.com> wrote:
Hi Torben,
Thank you. That worked great.
A related question: When I navigate to the REST endpoint for my styles I only see styles that have no workspace (ie. public, private, etc.). How can I view all styles, or at least the styles for a certain workspace?
On Mon, Nov 6, 2017 at 11:05 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello Kris,
If you are using 2.12.0, the instructions in the tutorial may be a little out of date. In addition to what is written there, you will need to set the Accept header. If you are using cURL, you can use the following command:
curl -u admin:geoserver -H “Accept: application/vnd.geoserver.ysld+yaml” -XGET http://localhost:8080/geoserver/rest/styles/point.yaml
Replace admin:geoserver with your username and password respectively, localhost:8080 with your host, and point with the name of the style.
This behaviour is a regression from 2.11 and earlier, we are looking into restoring the previous functionality but haven’t found a good fix yet.
Torben
Kris Johnson
Natural Resources Research Institute
5013 Miller Trunk Highway, Duluth, MN 55811
p: 218.788.2767
www.nrri.umn.edu
On Mon, Nov 6, 2017 at 6:22 AM, Kris Johnson <kristofj@anonymised.com> wrote:
Hello Torben,
Thank you for your response. See my answers below:
First of all, what version of GeoServer are you using? There have been a number of changes recently that could affect the behaviour you are seeing. Notably, GeoServer 2.12 includes a rewrite of the REST API that may be affecting this behaviour.
I am using geoserver version 2.12.0. What changes are you referring to? Are the instructions on this page (http://docs.geoserver.org/stable/en/user/styling/workshop/ysld/done.html) incorrect?
One thing you could try is setting the “Accept” header of your to "
application/vnd.geoserver.ysld+yaml".
I tried this suggestion without success (though this may be due to my lack of understanding on how to alter mime types).
Also, double-check that the YSLD extension is installed. One easy way to do this is to try creating a new style and verifying that YSLD shows up in the list of supported formats.
I can confirm that it is installed.:
As a final note, while SLD → YSLD conversion is supported, SLD → CSS is not (YSLD supports two-way conversion, but CSS can only be converted to SLD, not the other way around).
I am aware of this.
Thank you for any ideas you have that may assist me in this regard.
Kris Johnson
p: 218.788.2767
www.nrri.umn.edu
On Fri, Nov 3, 2017 at 4:53 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello Kris,
One thing you could try is setting the “Accept” header of your to “application/vnd.geoserver.ysld+yaml”.
Torben
Kris Johnson
p: 218.788.2767
www.nrri.umn.edu
On Thu, Nov 2, 2017 at 8:20 AM, Kris Johnson <kristofj@anonymised.com> wrote:
Hello,
I am attempting to convert an SLD style to a YSLD style following the instructions here: http://docs.geoserver.org/stable/en/user/styling/workshop/ysld/done.html
However, when I replace the .sld file extension with .yaml the page redirects back to the appearance of when the style is loaded with the .html extension.
I’ll attach the logfile, but here’s the main error that I’m seeing in the logs:
Failed to lookup template FedLands_NPS_FWS.ftl
java.io.FileNotFoundException: Template FedLands_NPS_FWS.ftl not found.
Kris Johnson
p: 218.788.2767
www.nrri.umn.edu
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.comrge.net
Kris Johnson
p: 218.788.2767
www.nrri.umn.edu
