[Geoserver-users] converting postgis geometry objects to wms images ???
Hello,
How can I create a wms image (e.g. png or gif ) from a set of postgis geometry objects ? Which java classes does geoserver use to do this ?
I need to this because i intend to use pgrouting as part of a new web application I am working on. In the application, I need to execute pgrouting queries that returns a set of postgis geometry objects, this geometry objects will have to be converted to a wms image and sent to the clients web browser. I know geoserver does this for other spatial queries as part of its wms implementation. I will like to know which classes geoserver uses to this.
Roman.
Hi, you may want to use the geotools renderer directly instead of loading up geoserver deps as a library, which it is not designed for. Yet, it would be possible to use geoserver's GetMapResponse from the wms module that way, but from what you tell I would be hesitant of carring out all the geoserver dependencies in a custom app just for that.
The geotools users guide contain some information on renderer and styling: http://docs.codehaus.org/display/GEOTDOC/12+Render
It should be quite simple to set up and more a library as you expect. Basically you just create a renderer, set it up with a map context holding the layers, styles, extent, map dimensions, etc you want your map rendered as, and get back a renderedimage.
hope that helps,
Gabriel
Roman Isitua escribió:
Hello,
Roman.
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Roman Isitua wrote:
Hello,
Basically we're using the PostgisDataStore to read the
database, and the the StreamingRenderer to render them into an image.
Both classes are actually in GeoTools.
