I’ve seen that there’s a way to provide Grid Shit trasform files to GeoServer (as .gsb or in the Nadcon format); I wonder if there’s a way to use the Italian “IGM Grigliati” files (.gr1 files).
Thank you,
Gianni.
Thank you,
Gianni.
On Fri, Aug 23, 2013 at 4:32 PM, Gianni Barrotta
<giannibarrotta@anonymised.com>wrote:
I've seen that there's a way to provide Grid Shit trasform files to
GeoServer (as .gsb or in the Nadcon format); I wonder if there's a way to
use the Italian "IGM Grigliati" files (.gr1 files).
Hmm... I don't believe so, unless they are ntv2 under a different name.
With some coding GeoTools/GeoServer could learn how to read and use them
though
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
thank you.
We should try and add this code, as we use this files in other applications.
May I open a Jira task?
On Fri, Aug 23, 2013 at 4:59 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Aug 23, 2013 at 4:32 PM, Gianni Barrotta <giannibarrotta@anonymised.com> wrote:
Hmm… I don’t believe so, unless they are ntv2 under a different name.
With some coding GeoTools/GeoServer could learn how to read and use them though
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Aug 26, 2013 at 12:25 PM, Gianni Barrotta
Hi Andrea,
thank you.We should try and add this code, as we use this files in other
applications.
Of course you can.
Ing. Andrea Aime
@geowolf
Technical Lead
