Hi, i had the problem to add *Font* or *Halo* to a simple TextSymbolizer.
Nothing validated - even not the examples from the GeoServer Online-Doc!
Then after 2 days i found that the *sequence of elements is important*.
Geometry, Label, Font, LabelPlacement, Halo a.s.o.
Question: Why do the examples not work for me? They don't use this sequence.
Or is there an option to disable this "feature"?
Running 2.7.2
Regards
walter
View this message in context: http://osgeo-org.1560.x6.nabble.com/could-not-add-font-or-halo-to-textsymbolizer-tp5221046.html
jive
2
There is no option to disable this feature (it is a part of how XML works).
Do you have a specific documentation page that is wrong? If so please see Quickfix to change the page.
On 25 August 2015 at 13:23, walter.nordmann <walter.nordmann@anonymised.com> wrote:
Hi, i had the problem to add Font or Halo to a simple TextSymbolizer.
Then after 2 days i found that the sequence of elements is important.
Question: Why do the examples not work for me? They don’t use this sequence.
Or is there an option to disable this “feature”?
Running 2.7.2
Regards
walter
Geoserver-users mailing list
Jody Garnett
