2014-03-29 21:24 GMT+01:00 pablo zader <pzader@anonymised.com>:
Hi Daniele
Thanks.
As I know if the image is georectificada?
Below sending command output ncdump.
Pablo
$> ncdump -h TUW_METOP_ASCAT_WARP55R12_2313.nc
netcdf TUW_METOP_ASCAT_WARP55R12_2313 {
dimensions:
dayofyear = 366 ;
obs = 45487 ;
gp = 19 ;
variables:
byte topo(gp) ;
topo:units = “%” ;
topo:long_name = “Topographic complexity” ;
topo:missing_value = -1b ;
topo:coordinates = “lat lon” ;
topo:valid_range = 0b, 100b ;
short proc_flag(obs) ;
proc_flag:flag_meanings = “default soil_moisture_set_to_0_since_it_was_between_0_and_-50 soil_moisture_set_to_100_it_was_between_100_and_150 soil_moisture_set_to_NaN_it_was_below_-50 soil_moisture_set_to_NaN_it_was_above_150 normalised_backscatter_is_out_of_limits_or_dry_wet_reference_is_NaN” ;
proc_flag:coordinates = “time lat lon” ;
proc_flag:valid_range = 0s, 128s ;
proc_flag:long_name = “Processing flag” ;
proc_flag:flag_values = 0s, 1s, 2s, 4s, 8s, 16s ;
proc_flag:missing_value = -1s ;
int gpi(gp) ;
gpi:long_name = “Grid Point Index” ;
gpi:cf_role = “timeseries_id” ;
gpi:coordinates = “lat lon” ;
gpi:valid_range = 0, 3264390 ;
byte frozen(gp, dayofyear) ;
frozen:units = “%” ;
frozen:long_name = “Frozen probability” ;
frozen:missing_value = -1b ;
frozen:coordinates = “doy lat lon” ;
frozen:valid_range = 0b, 100b ;
float lon(gp) ;
lon:units = “degree_east” ;
lon:long_name = “Grid point longitude” ;
lon:standard_name = “longitude” ;
lon:valid_range = -180.f, 180.f ;
byte snow(gp, dayofyear) ;
snow:units = “%” ;
snow:long_name = “Snow probability” ;
snow:missing_value = -1b ;
snow:coordinates = “doy lat lon” ;
snow:valid_range = 0b, 100b ;
float por_hwsd(gp) ;
por_hwsd:_CoordinateAxes = “lat lon” ;
por_hwsd:coordinates = “lat lon” ;
por_hwsd:valid_range = 0.f, 1.f ;
por_hwsd:long_name = “Porosity derived from HWSD” ;
por_hwsd:units = “m3 m-3” ;
por_hwsd:missing_value = -1.f ;
int row_size(gp) ;
row_size:long_name = “Number of observations for this grid point” ;
row_size:sample_dimension = “obs” ;
short doy(dayofyear) ;
doy:units = “days” ;
doy:long_name = “Day of year” ;
byte wetland(gp) ;
wetland:units = “%” ;
wetland:long_name = “Inundation and wetland fraction” ;
wetland:missing_value = -1b ;
wetland:coordinates = “lat lon” ;
wetland:valid_range = 0b, 100b ;
char orbit_dir(obs) ;
orbit_dir:long_name = “Orbit direction” ;
orbit_dir:coordinates = “time lat lon” ;
byte sm(obs) ;
sm:units = “%” ;
sm:long_name = “Soil Moisture” ;
sm:missing_value = -1b ;
sm:coordinates = “time lat lon” ;
sm:valid_range = 0b, 100b ;
double time(obs) ;
time:units = “days since 1970-01-01 00:00:00” ;
time:long_name = “time of measurement” ;
time:standard_name = “time” ;
float lat(gp) ;
lat:units = “degree_north” ;
lat:long_name = “Grid point latitude” ;
lat:standard_name = “latitude” ;
lat:valid_range = -90.f, 90.f ;
float por_gldas(gp) ;
por_gldas:_CoordinateAxes = “lat lon” ;
por_gldas:coordinates = “lat lon” ;
por_gldas:valid_range = 0.f, 1.f ;
por_gldas:long_name = “Porosity resampled from NASAs LDAS” ;
por_gldas:units = “m3 m-3” ;
por_gldas:missing_value = -1.f ;
byte ssf(obs) ;
ssf:flag_meanings = “unknown unfrozen frozen_temporary melting_water_on_the_surface permanent_ice” ;
ssf:coordinates = “time lat lon” ;
ssf:valid_range = 0b, 4b ;
ssf:long_name = “Surface State Flag” ;
ssf:flag_values = 0b, 1b, 2b, 3b, 4b ;
ssf:missing_value = -1b ;
byte sm_noise(obs) ;
sm_noise:units = “%” ;
sm_noise:long_name = “Soil Moisture Noise” ;
sm_noise:missing_value = -1b ;
sm_noise:coordinates = “time lat lon” ;
sm_noise:valid_range = 0b, 100b ;
// global attributes:
:geospatial_lon_min = 144.65f ;
:featureType = “timeSeries” ;
:geospatial_lat_max = -40.75f ;
:time_coverage_end = “20130712T000000Z” ;
:title = “Metop ASCAT Soil Moisture Time Series” ;
:geospatial_lon_resolution = “12.5 km” ;
:product_version = “WARP 5.5 Release 1.2” ;
:geospatial_lat_min = -41.65f ;
:geospatial_lat_resolution = “12.5 km” ;
:time_coverage_start = “20070101T000000Z” ;
:Conventions = “CF-1.6” ;
:project = “H-SAF” ;
:source = “Metop ASCAT Level 1b 25km backscatter” ;
:cdm_data_type = “Time Series” ;
:platform = “Metop-A” ;
:creator_url = “http://rs.geo.tuwien.ac.at/” ;
:id = “2313.nc” ;
:date_created = “2013-10-01 18:01:35” ;
:sensor = “ASCAT” ;
:institution = “Vienna University of Technology” ;
:geospatial_lon_max = 145.f ;
Geoserver-users mailing list
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Nicola Lagormarsini
Junior Software Engineer
Via Poggio alle Viti 1187
2014-03-28 13:21 GMT-03:00 Daniele Romagnoli <daniele.romagnoli@anonymised.com>:
Hi Pablo,
could you please provide some more info about your sample data? (an ncdump or something similar)
I have played a bit with some Ascat sample some months ago and the sample data I had, need to be georectified before being used.
Not sure if that’s your case but geoserver currently supports only georectified wgs84 NetCDF-CF datasets (We are about to support more projections).
So an overview report about your sample data structure may be helpful.
Please, let us know.
Daniele
Pablo J. Zader
Lic. en Cs. de la Computación
CONAE
pablo.zader@anonymised.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
Ing. Daniele Romagnoli
Senior Software Engineer
On Fri, Mar 28, 2014 at 5:08 PM, pablo zader <pzader@anonymised.com> wrote:
Hello list:
I need to load NetCDF files to Geoserver.
I have installed the two plugins in Geoserver (netcdf-plugin and netcdf-out-plugin) for Netcdf from:http://ares.opengeo.org/geoserver/2.4.x/community-latest/
I am working with the cURL library to load NetCDF files, but I get the following response with error:
- About to connect() to localhost port 80 (#0)
- Trying 127.0.0.1… connected
- Server auth using Basic with user ‘admin’
PUT /geoserver/rest/workspaces/satelite/coveragestores/ascatncdf/file.netcdf HTTP/1.1
Authorization: Basic YWRtaW46ZzI0czJydjJy
User-Agent: curl/7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1 zlib/1.2.3.4 libidn/1.23 librtmp/2.3
Host: localhost
Accept: /
Content-type: application/zip
Content-Length: 9215392
Expect: 100-continue
< HTTP/1.1 100 Continue
< HTTP/1.1 500 Internal Server Error
< Server: Apache-Coyote/1.1
< Content-Type: text/plain
< Transfer-Encoding: chunked
< Date: Fri, 28 Mar 2014 11:23:11 GMT
< Connection: close
Could not aquire reader for coverage <–here the error!!!
My instruction is:
curl -v -u admin:geoserver -XPUT -H “Content-type: application/zip” --data-binary @./ASCAT.zip http://localhost/geoserver/rest/workspaces/satelite/coveragestores/ascatncdf/file.netcdf
I also tried to charge it through the administrative interface gesoserver, but I get the following error:
Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:satelites/ASCAT.nc and hints null
I am using:
Geoserver 2.4
curl 7.22.0
Ubuntu 12.04
I hope your help.
Thanks
Pablo
Pablo J. Zader
CONAE
